Speedometer MPH to KPH Conversion - face source??
ysmalkie
Poland
#1 Speedometer MPH to KPH Conversion - face source??
Post by ysmalkie » Wed Apr 15, 2020 7:18 pm
Has anyone discovered a source of GOOD QUALITY KPH faces?
I found this the other day:
https://www.heiler-tachodesign.de/
but have no idea on the quality..
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
vee12eman
Kiribati
#2 Re: Speedometer MPH to KPH Conversion - face source??
Post by vee12eman » Wed Apr 15, 2020 8:08 pm
I don’t know if it’s still available, but I converted mine with a face from SNG about nine years ago.
Series III FHC
#3 Re: Speedometer MPH to KPH Conversion - face source??
Post by Series1 Stu » Wed Apr 15, 2020 8:56 pm
Hi Tadek
I got a MPH face for my 356 Speedo from them. Absolutely top quality and great service.
Our friend Carsten helped me out a little too.
ysmalkie
Poland
#4 Re: Speedometer MPH to KPH Conversion - face source??
Post by ysmalkie » Thu Apr 16, 2020 6:39 am
I think that the KPH faces SNG does do not fir the Series 1 unfortunately..
Tadek
Tadek
Jaguar XK120 OTS
#5 Re: Speedometer MPH to KPH Conversion - face source??
Post by christopher storey » Thu Apr 16, 2020 9:08 am
It is not very difficult to make your own and stick it over the existing face, although it does take patience and a modicum of skill . There are plenty of photos around of kph S1 faces, and you can then use a photoediting programme to size it exactly to your requirements
ysmalkie
Poland
#6 Re: Speedometer MPH to KPH Conversion - face source??
Post by ysmalkie » Thu Apr 16, 2020 5:05 pm
Thanks Chris,
That's easy, I know - I was thinking of a more sophisticated, original looking solution.... ;-)
Tadek
Tadek
Jaguar XK120 OTS
#7 Re: Speedometer MPH to KPH Conversion - face source??
Post by mgcjag » Thu Apr 16, 2020 5:18 pm
Hi Tadek...contact one of the instrument repair/calibration guys like http://www.speedograph-richfield.com/ https://speedycables.com/
#8 Re: Speedometer MPH to KPH Conversion - face source??
Post by PeterCrespin » Fri Apr 17, 2020 10:50 am
Caerbont Automotive instruments are the makers of Smiths instruments and still supply anything you need. They also license Nisonger in the USA.
MarekH
#9 Re: Speedometer MPH to KPH Conversion - face source??
Post by MarekH » Fri Apr 17, 2020 2:41 pm
Dear Tadek,
Take a high resolution photo of the one you have and alter it in one of the many photoshop type programmes to suit your requirements. Then send the file away to have a Letraset transfer made. This will come back as a silkscreen rub down dry transfer. Spray your face black, apply the transfer and rub down.
Resolution will be ~1000dpi.
Up to four colours per A4 sheet.
Cost (about 25years ago when I last did a speedo) was ~£25 per A4 sheet.
The place I went was 4D models who used to be near Angel but moved to somewhere near Tower Bridge. I suspect now we have a world wide interweb, other providers are available.
The result is a 100% oem finish. Since you can fit ~6 speedos onto the A4 with a variety of the text variations, then our fellow listers will even pay for your speedo and the rest of your restoration.....:bigrin:
The next alternative is pad printing, i.e. custom tampo printing, but working with wet ink sometimes has its quirks and some characters simply don't print quite as expected. (This will be how the original was done - the Letraset will have a flatter paint layer. If you are precise, then you can layer one on top of another (at the expense of your profit margin :cussing: )).
ysmalkie
Poland
#10 Re: Speedometer MPH to KPH Conversion - face source??
Post by ysmalkie » Sat Apr 18, 2020 6:51 pm
Very interesting Marek - however the e-type speedo face is dished. Will it work ???
Tadek
Tadek
Jaguar XK120 OTS
MarekH
#11 Re: Speedometer MPH to KPH Conversion - face source??
Post by MarekH » Sat Apr 18, 2020 8:37 pm
I don't see why not. Although the paint decal comes on a mylar sheet base, you are free to cut it up with a sharp scalpel any how you like
I'd cut the mylar sheet into a broad 270 degree arc and lay that flat on the dished surface. You don't even need to rub everything down in one go - you can do just the circular bit and then overlay the numbers later.
Go purchase some black paint, a broken Smiths speedo (for its faceplate) and a sample of any silkscreen rubdown transfer and see what you think of it. Your only downside is that you are going sand down and respray it anyway.
#12 Re: Speedometer MPH to KPH Conversion - face source??
Post by PeterCrespin » Sun Apr 19, 2020 11:29 pm
“Spray your face black, apply the transfer and rub down”
I would put some barrier cream on first and check how busy the dermatology clinics are.
