Door lock fixing screw sizes
PaulColeman
Topic author - Posts: 247
#1 Door lock fixing screw sizes
On the door locks there are 4 fixing screws. Three of them are 2BA and screw into the nuts on the lock but the other one is a straight nut and bolt - does anybody know what size this is supposed to be as 2BA seems too big.
Thanks, Paul.
Thanks, Paul.
1965 Series 1 FHC
1976 Lotus Esprit
1976 Lotus Esprit
#2 Re: Door lock fixing screw sizes
I'm struggling to visualise which screws you are talking about.
AFAIK all the fixings are UNF... Can you do a picture?
PaulColeman
#3 Re: Door lock fixing screw sizes
It's the hole that's circled. The other three fixings in the lock are tapped holes but this other one isn't...
1965 Series 1 FHC
1976 Lotus Esprit
1976 Lotus Esprit
#4 Re: Door lock fixing screw sizes
PaulColeman
#5 Re: Door lock fixing screw sizes
Hmm... strange. Mine only have three holes tapped like the replacement ones that SNG sell? The strange thing is that the single un-tapped hole is smaller than the other three.
1965 Series 1 FHC
1976 Lotus Esprit
1976 Lotus Esprit
#6 Re: Door lock fixing screw sizes
On my 1963 coupe in the garage all 4 are tapped.
The diagram you have from SNGB shows C20095 and I agree the holes aren't tapped. The parts manual for your car lists 6 screws so that's probably correct.
The code for the screw is UFS 419 3/H which means
Unified
Fine
Setscrew
Round head slotted
3/16" diameter
3/8" long
Screwdriver driven
PaulColeman
#7 Re: Door lock fixing screw sizes
Thanks for the info. I was expecting 3 screws per lock for the tapped holes plus another screw and nut of a smaller size for the other hole? My door shells are like the ones in the picture above with 4 fixing holes.abowie wrote: ↑Mon May 04, 2020 9:09 pmOn my 1963 coupe in the garage all 4 are tapped.
Unified
Fine
Setscrew
Round head slotted
3/16" diameter
3/8" long
Screwdriver driven
1965 Series 1 FHC
1976 Lotus Esprit
1976 Lotus Esprit
#8 Re: Door lock fixing screw sizes
Interesting?
There is definitely four set screws in mine and I had a look at the CMC restoration manual and on page 191 you can see the same??
However, looking at my photo of the rear of the lock, it appears that that hole may possibly not be originally threaded??
But why would Jaguar do that?
PaulColeman
#9 Re: Door lock fixing screw sizes
Is it because some part of the internal mechanism would foul on it and therefore the screw has to be really short? That hole is not tapped in mine though so I'm probably talking rubbish! It's also smaller than the other holes.
1965 Series 1 FHC
1976 Lotus Esprit
1976 Lotus Esprit
#10 Re: Door lock fixing screw sizes
Looking closely at my picture there are 2x BD20780/3 which are "shakeproof screws".PaulColeman wrote: ↑Tue May 05, 2020 9:35 amplus another screw and nut of a smaller size for the other hole?
I bet that's what goes in your holes.
