mach2andy
Post
by mach2andy » Sun May 31, 2020 9:21 am
Andy
1970 S2 FHC
1965 SB Corvette Ragtop
Tom W
Post
by Tom W » Sun May 31, 2020 9:47 am
This is useful, gives me some confidence I might be able to get mine going again.
Tom
1970 S2 FHC
mach2andy
Post
by mach2andy » Sun May 31, 2020 10:30 am
Hi Tom
My mate warned me that transistors are a bit sensitive to heat and suggested using a pair of pliers to each leg as a heatsink when soldering. I tinned each leg using pliers as a heat shrink, and then made the joints very quickly. It seems to have worked.
Andy
1970 S2 FHC
Drive35
Post
by Drive35 » Mon Jun 01, 2020 8:56 am
Nice one Andy. Mine's the same, although it does work when the switch panel is left folded down
Was wondering whether to take it apart, but don't know if the transistor is at fault, or it's just worn out!
1970 S2 2+2
mach2andy
Post
by mach2andy » Mon Jun 01, 2020 9:40 am
Hi Geoff
I'm no expert, but if it's sensitive to attitude, it's more likely to be a mechanical issue I would have thought? I was going to buy a secondhand clock on eBay out of a Scimitar, but the seller said that his clock was sensitive to attitude as well. The Scimitar clock is slightly different in that the setting and adjustment knobs are at the bottom, not the top.
A guy in the US who has repaired a thousand of these clocks was very helpful to me. His name is Michael Eck
eckmichael@comcast.net. When I described my fault he said straight away that the transistor was bad.
Or you can have the guts replaced with a quartz mechanism? The cost is about £90 I think?
ATB
Andy
Andy
1970 S2 FHC
Pianoman
Post
by Pianoman » Mon Jun 01, 2020 3:42 pm
the clock in mine is a bit strange. if I have the panel tilted forward then the clock runs and keeps perfect time but when I push the panel back upright then the clock stops !!!
Donal Norton
1969 E Type FHC Series 2 Unrestored Driver
Drive35
Post
by Drive35 » Sun Jun 07, 2020 8:29 am
Thanks for the link, Andy.
Mike Eck confirmed it's the coiled wire 'balance wheel' which warps over time and doesn't move freely when upright. Not easily repairable, apparently, but I'll still have a go sometime.
Have copied the email to you Pianoman
1970 S2 2+2
Pianoman
Post
by Pianoman » Sun Jun 07, 2020 8:40 pm
Thanks Geoff,
My other solution is that when I want to see the time, I could just jack up the front of the car
Donal Norton
Monkeyfinger
Post
by Monkeyfinger » Thu Jun 18, 2020 1:52 pm
Just a note with respect to the Scimitar clock. My original battery powered clock was completely broken internally and useless.Whilst the Scimitar clock appears to have the knobs at the bottom, it's just turned 180 degrees relative to the 'E'. I bought a 12v Scimitar one off Ebay and just swapped the clock face over. Just 2 small screws on the face, and the hands simply pull off. Bezels can also be swapped. Main advantage was the price difference compared to a working E type clock.
Pianoman
Post
by Pianoman » Fri Jun 19, 2020 7:24 pm
great idea, thanks
Donal Norton
