Air filter drum support bracket
Harveysearle
#1 Air filter drum support bracket
Post by Harveysearle » Sun Nov 15, 2020 3:50 pm
Hi guys has anyone got a picture they could send me of the air cleaner support drum bracket underneath that the drum rests on. Mine was missing so trying to fit one but can’t see where it bolts on to as new panels in
Thanks harvey
#2 Re: Air filter drum support bracket
Post by mgcjag » Sun Nov 15, 2020 4:55 pm
Not exactlyvwhat you want but may help.....have you searched here on the forum. ...Steve http://forum.etypeuk.com/viewtopic.php?t=8575
neal herridge
#3 Re: Air filter drum support bracket
Post by neal herridge » Sun Nov 15, 2020 5:10 pm
Hi Harvey.
If you have new toe boards fitted if you look inside the car you will see a nut insert that is not used by the engine frame fixing bolts but its not been drilled through the panel.
This is what you need, just drill through from inside the car first with the tapping size drill & then open up very carefully from the out side but only for the panel thickness do not drill out the thread.
This is the mounting for that bracket , there should be one punched in the sill end plate already.
Neal.
AshM
#4 Re: Air filter drum support bracket
Post by AshM » Sun Nov 15, 2020 5:26 pm
I have some photographs for you Harvey but seem to have lost the method of posting them.
Anyone can help me with my dimness.
thanks
Ash
Series 2 FHC 1970
1R 20607
#5 Re: Air filter drum support bracket
Post by mgcjag » Sun Nov 15, 2020 5:31 pm
Hi Ash......once you type your post at the bottom of the page you should see highlighted...add image to post...select this then select your image....Steve
AshM
#6 Re: Air filter drum support bracket
Post by AshM » Sun Nov 15, 2020 6:11 pm
Thanks Steve - I am sure it is me but that did not appear to be there earlier.
Anyway - there now so a couple here that may help Harvey.
cheers
Ash
Series 2 FHC 1970
1R 20607
Harveysearle
#7 Re: Air filter drum support bracket
Post by Harveysearle » Sun Nov 15, 2020 6:19 pm
Thank you very much guys for all the info, Great help.
That’s perfect, pictures are brilliant.
I can crack on now with that. Till the next thing lol
harvey
Bfastr
#8 Re: Air filter drum support bracket
Post by Bfastr » Sun Nov 15, 2020 6:34 pm
here are a couple pics of the bracket before it was painted.
Bob F
69 S2 E-type OTS LHD
Stevejaguar
#9 Re: Air filter drum support bracket
Post by Stevejaguar » Wed Nov 18, 2020 2:12 pm
Interesting in that I also thought that the air cleaner bracket should be painted black. But should the vac tank also be black ? Mine has been silver for the last 30 years.
Philk
#10 Re: Air filter drum support bracket
Post by Philk » Wed Nov 18, 2020 2:49 pm
Stevejaguar wrote: ↑
The tank should definitely be black with "Trico Reservac" stencilled on it. See link below
http://forum.etypeuk.com/viewtopic.php? ... 72e35a5b4
1964 S1 3.8 OTS
#11 Re: Air filter drum support bracket
Post by Heuer » Wed Nov 18, 2020 3:13 pm
The Reservac stencil was only used up until late 1965 IIRC so correct if your car predates that.
