Lucas relays
Fspp369
#1 Lucas relays
Post by Fspp369 » Fri Feb 05, 2021 5:21 pm
Not sure if this is any use to anyone but here you go..
Handy little list of 6RA relays etc from the TVR club.just click on the first google suggestion.
It’s from the club across the pond.
http://tvrna.tvrccna.org/lucas/lucas-relays-6ra.htm
If I’m behind the times accept my apologies.
Peter
Peter {XKE V12HE efi}
XKRS
Octavia VRS.
cactusman
#2 Re: Lucas relays
Post by cactusman » Fri Feb 05, 2021 5:34 pm
Excellent.....many thanks for posting.... :bigrin:
#3 Re: Lucas relays
Post by abowie » Fri Feb 05, 2021 10:28 pm
I have this as a PDF.
David do you want it for the KB?
rossco_j
#4 Re: Lucas relays
Post by rossco_j » Sat Feb 06, 2021 1:37 am
I think a .pdf file in the knowledge base is an excellent idea.
Ross
1972 Series 3 E Type 2+2
1972 MGB GT
1965 Mini Cooper
1954 Austin A30
https://rossjohnsonphotography.zenfolio.com/
MarekH
#5 Re: Lucas relays
Post by MarekH » Sat Feb 06, 2021 8:40 am
Aside from the starter motor relay, you can usually make what you need out of a changeover relay. For most of the variants used on the car, simply externally connect the c2 terminal to one of the w terminals and leave the unwanted terminal unconnected.
Fspp369
#6 Re: Lucas relays
Post by Fspp369 » Sat Feb 06, 2021 8:48 am
If you click on the original link just then click print and the pdf is usually created...save or print. ..!
Peter
XKRS
Octavia VRS.
#7 Re: Lucas relays
Post by PeterCrespin » Sat Feb 06, 2021 10:12 am
Fspp369 wrote: ↑
Handy little list.. from the TVR club across the pond.
http://tvrna.tvrccna.org/lucas/lucas-relays-6ra.htm Peter
Steady on lads. This has the potential to be a ‘super-spreader’ file... Using anything from the TVR crowd could turn our cars into fibreglass with half-inch panel gaps, and make the dash switches and window winders snap off after first use!
Fspp369
#8 Re: Lucas relays
Post by Fspp369 » Sat Feb 06, 2021 12:32 pm
Ahh Yes but once you've been impregnated, once now and if necessary, again later (yet to be decided) you won't get any body rot😉
XKRS
Octavia VRS.
#9 Re: Lucas relays
Post by Heuer » Sat Feb 06, 2021 2:14 pm
Already in the KB, been there since August 2018 but thanks for the thought.
