Hi there. Just a quick bit of advice please. Does anyone know if the thicker brake discs from a Mk10 jaguar will fit to the e type asa direct swap. i seem to recall reading that this was a common mod back in the 60,s
thanks
Tim
series 1 brakes
Nevr done it but I belive the saloon discs were slightly larger diameter, hence bracket required to mount cylinders further out. Series 2 E-type discs are thicker only 1/2 instead of 3/8"
alangordonman
Forget it go for a set of Coopercraft they are magic and bolt straight on. Alan
