Battery size
#1 Battery size
Hi Can anyone help with the correct battery dimensions. Searching on most on-line sites for a new one, the size of battery comes up as 261mm by 170mm by 200mm as the correct size battery for a series 1 4.2 OTS. However on measuring the old battery and the tray it would seem to be 254mm by 170mm, in fact if I was to select the size as recommended it would be a tight fit, and definitely it would be impossible to secure. Has anyone else found this oddity. Thanks Sean
#2 Re: Battery size
When searching for a replacement battery take the hold down bracket with you as sizes vary even though they are all supposed to be DIN 56011 spec size - 236 x 178 x 182mm (LWH). The Halfords HBO30 is a good fit and a decent price. More info in this thread: http://forum.etypeuk.com/viewtopic.php?p=135506#p135506
#3 Re: Battery size
Batteries on the European market may be a bit different, a standard size is 242 mm x 175 mm x 190 mm, which fits the tray - at least mine. Available in 60 Ah and a lot of brands to choose from, also available in efb technology.
1963 OTS 880436
1963 OTS 880436
#4 Re: Battery size
Thanks that's helpful. So much for supplier on-line selection. I will use the tray size as the best way to select the battery.
#5 Re: Battery size
You need the top bracket as well! The Halfords one fits perfectly.
#6 Re: Battery size
I've bought two batteries in the last couple of months and got them online from The Battery Shop. They give accurate dimensions for each battery and have a wide choice. You can spend many happy hours finding your ideal battery. They deliver in a couple of days for around £10. Prices are as good as anywhere else.
No connection other then as a satisfied customer.
