Dashboard removal
Pgxxl
#1 Dashboard removal
Post by Pgxxl » Thu Apr 01, 2021 10:17 pm
How easy is it to remove series 3 ots dashboard ?
1972 OTS
Opalescent silver blue
Purchased Oct 2020
MarekH
#2 Re: Dashboard removal
Post by MarekH » Fri Apr 02, 2021 6:45 am
It is very easy.
The dashboard is made up of two parts.
The part nearer the cabin is held by just four nuts holding onto four captive bolts on its lower face. Two are reached from under the dash at the door edges and other two are visible once the centre gauges panel is lowered.
If you need to remove the second panel, the one nearer the windscreen, then you can now see the four nuts and bolts holding it to the chassis at the centre gauges.
