Door water deflectors
vipergts
#1 Door water deflectors
Post by vipergts » Thu Apr 08, 2021 6:57 pm
Does anyone reproduce the water deflectors that are riveted to the door shell behind the door card to prevent water from splashing outward?
S1 4.2 Roadster in Resale Red
JimmyS
#2 Re: Door water deflectors
Post by JimmyS » Thu Apr 08, 2021 10:30 pm
1964 FHC Project
1E20078
paulsco
#3 Re: Door water deflectors
Post by paulsco » Fri Apr 09, 2021 1:48 pm
I think Vipergts means these:
These are homemade; I don't think they are available to buy??
Philk
#4 Re: Door water deflectors
Post by Philk » Fri Apr 09, 2021 3:42 pm
The image is not opening on the screen?
1964 S1 3.8 OTS
paulsco
#5 Re: Door water deflectors
Post by paulsco » Fri Apr 09, 2021 4:16 pm
I’ve edited the picture, but postimage is not showing it for some reason, maybe postimage has a problem at the moment?
paydase
#6 Re: Door water deflectors
Post by paydase » Fri Apr 09, 2021 5:20 pm
I have them also on my car.
Not in alloy but in steel, painted black, riveted:
Serge
1964 (3.8) FHC
1961 OTS
vipergts
#7 Re: Door water deflectors
Post by vipergts » Fri Apr 09, 2021 5:32 pm
Yeah they’re the ones.
Resigned myself to making some which I did today.
Will seal them on and the membrane with dumdum
I’m determined to stop water ingress
1954Etype
#8 Re: Door water deflectors
Post by 1954Etype » Fri Apr 09, 2021 5:49 pm
Don’t forget the nylon receivers in the bottom row of door card clips. Also, the lower clips are different to the others (made from wire)
Angus 67 FHC 1E33656
61 OTS 875047
paulsco
#9 Re: Door water deflectors
Post by paulsco » Fri Apr 09, 2021 6:11 pm
Interesting Angus, I wasn't aware of the nylon receivers I just have the ordinary steel ones, through the drilled holes.
Were they fitted to the Series Ones?
I will have to look into that.
Thanks,
paydase
#10 Re: Door water deflectors
Post by paydase » Fri Apr 09, 2021 9:02 pm
Yes interesting.
I was surprised to see these: have they a specific function (maybe against corrosion)?
P1200093 (2).jpg (190.24 KiB) Viewed 15894 times
Serge
1964 (3.8) FHC
1961 OTS
288gto
Russia
#11 Re: Door water deflectors
Post by 288gto » Sat Apr 10, 2021 8:00 am
I think they were to try to prevent water that might collect in the bottom of the doors, getting past. It can come out onto the inner sill and also damage the door cards. Always make sure the drain channels are clear. It's easy to block these if you have waxoyled inside the doors.
paulsco
#12 Re: Door water deflectors
Post by paulsco » Sat Apr 10, 2021 8:54 am
The parts manual for the Series One doesn't mention them, nor do they appear on the SNG site for the Series One.
They are however listed for the Series Two.
I would have concluded that they were a later addition if it wasn’t for Surge's 3.8.
I would agree with Simon that they are there to prevent water getting past.
paulsco
#13 Re: Door water deflectors
Post by paulsco » Sat Apr 10, 2021 9:03 am
Well would you believe it.
I have just had a look at some old photos and they were original on my car too.
vipergts
#14 Re: Door water deflectors
Post by vipergts » Sat Apr 10, 2021 2:49 pm
1954Etype wrote: ↑
Angus, I do have the nylon receivers/plugs in the doors though a bit mashed. (Incidentally I found them for 36p at Robeys, cheapest yet).
They’re definitely to stop water ingress.
BUT, what’s different about the lower clips, aren’t they all wire?
Lee
1954Etype
#15 Re: Door water deflectors
Post by 1954Etype » Sat Apr 10, 2021 3:49 pm
Hi Lee, only the clips for the nylon plugs are wire. I think they grip better inside the plug.
Angus
61 OTS 875047
vipergts
#16 Re: Door water deflectors
Post by vipergts » Sat Apr 10, 2021 3:57 pm
Gotcha. All my clips seem to be wire.
ysmalkie
Poland
#17 Re: Door water deflectors
Post by ysmalkie » Tue Apr 13, 2021 4:18 pm
The plastic receivers are also on my Oct 63 car.
what's their PN?? I cannot locate it in the SPC.. :-(
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
#18 Re: Door water deflectors
Post by mgcjag » Tue Apr 13, 2021 4:24 pm
Aftermarket replacements from SNGB.....they are a common type of clip reciever should be available from many trim suppliers.....Steve https://www.sngbarratt.com/English/#/UK ... 202350636)
paulsco
#19 Re: Door water deflectors
Post by paulsco » Tue Apr 13, 2021 5:34 pm
The SNG ones appear to be a slightly different design in that the outside face is circular and not tabs like the originals. Probably makes no difference to is function, but it is nice to have parts that look like the original.
They are also 90p each.
I have ordered some from Martin Robey, where they are 43p inc. and look like the originals.
I will report back when I receive them.
ysmalkie
Poland
#20 Re: Door water deflectors
Post by ysmalkie » Tue Apr 13, 2021 6:28 pm
Thanks Steve,
Tadek
Tadek
Jaguar XK120 OTS
