I have purchased a composite head gasket from a jag suppler (not one of the usual).
What is confusing me is that the bore sizes on the gasket are 84mm but a 3.8 cylinder bore size is 87mm.
This started me thinking and after some research I have found that you can get a single gaskets that covers both the 3.8 and 3.4 jag engine. (e.g. Cometic C4303). This would explain the 84mm bore which must suite the 3.4 engine.
So..... If used on a 3.8 engine, the metal lip around the gasket bore must intrude into the combustion chamber area by a small amount (1.5mm). The piston does not quite reach the top of the cylinder at full stroke so I guess this isn't a problem but 2 things are bothering me:
1. There would be less of the metal 'ringed' part of the gasket getting squashed by the compression of
torqueing down the head. (remember it's a composite)
2. Would this not affect compression ratio slightly? (The gasket is 1.5mm thick.)
I'm not sure about using it but is there any head gasket experts out there that could put my mind at rest??
Any reassurance appreciated.
Sean
