I've just received a pair of hood tie down straps from SNG Barratt, the ones that attach to the hood bow and swivel to hold the hood down in its folded position. At over £100 not cheap but their sales guy assured me they were premium quality items.
A few questions to help me fit them properly and even better if anyone has pictures.
Can anyone confirm the correct shape of the ends that have the lift the dot fasteners as my new ones may need trimming to the correct shape . At present mine are more the shape of a 50p piece where they have been roughly cut to size. I think the final bit of shaping is up to the customer so if anyone has a pic of an original that would be great. Also should the lift the dot fastener be central or offset and slightly at an angle. Are they handed as one seems a significantly different shape to the other?
Moving on to the other end that is permanently fixed to the hood, should the small shouldered spacer washer fit inside the strap end. Mine doesn't so when you tighten it, it prevents the strap from swivelling. Do you just leave the screw loose so it can swivel on that. The only problem with that is the strap end then jams on the screw and washer as it turns.
Can someone confirm that my strap ends are angled the right way , in towards the hood rather than out from the hood. The sharp and jagged edges of the metal strap ends are going to damage the hood material. I'm thinking it might be better to get new ends made and washers that fit properly.
The central part of the strap isn't too bad, I think I maybe need to make new ends and fixings . I'm optimistic that I have the first 10% of a strap that will work so if anyone can supply pics or suggestions on how to make the last 90% that would be hugely appreciated.
Pics of the new SNG Barratt ones....
Thanks,
