I've found many posts on here and jag-lovers about the various camshafts and have seen the Georgiajag guide, which explains the differences, however my 1970 4.2 'original' engine has a 4-hole cam on the exhaust side with the groove around the flange (haven't checked the other side yet), which doesn't feature in the options!
I note the sprocket only has 2 holes and apparently a bodge with the wired bolts? Don't know if the cylinder head has been replaced at some time.
I'm in the process of fitting tappet guide hold-down plates, but am confused by the camshaft info. The tappet clearances are all about .006", which doesn't appear to be correct for my car (.012-014"), however it runs OK (apart from noisy tappet guides) and did 250 miles last weekend to Bicester.
Should I be concerned
