Hi all,
a few years back I had to replace the old pump in my -67 S1 2+2 , did so with a new electronic one. This spring I took the car for a first short run. Stopped at a point and when trying start again the battery was dead (battery had been maintained all winter), jump started downhill, almost at home it stopped again. I could now determine that the pump had broken down. Bought a new one, working all summer, no problem with battery/charging. Yesterday the new gave up as well. Anyone had this problem, is it just bad luck or could it have been some kind of spikes as the pump is electronic, bad voltage regulator?
Any help much appreciated
Baaz
Fuel pump problem or...
#2 Re: Fuel pump problem or...
An update
my bad, the new one I bought was not an electronic but original type. Took it apart yesterday and with some lubrication it's working again:) What happened with the battery/charging and the electronic one this spring is still a mystery...
Baaz
Baaz
