Flanges purchased from Chuck at Monocoque Metalworks
Chuck also supplied the clear plastic covers. I have the glass ones as well
I have plenty of questions so would be grateful for help from S1 owners
As for attaching the flanges- my thinking so far is to lap the flanges under the existing edge using the rivet holes for the S1.25/S1.5 scoops and maybe add one or two more and then maybe the odd mig weld tack at each end. I'll coat all surfaces in POR15
Reasoning...
1. Minimal mods. Can revert back to original spec if required (Chuck)
2. No butt welding to the existing bonnet opening which involves total refinishing of the bonnet (not ready for that yet)
Questions so far:
1. There is talk of a metal support under the sugar scoop at the front. Any shots of this would be useful. Got it thx.
2. I do have a pair of used rubber seals but who sells the best ones if these prove tricky to fit?
3. Headlamp connector is fouling the back of the headlamp bowl when you attach it to the seating bowl (new thread). Now fixed. Cure is Wipac lamps which are not ass deep. Work around needs connector plug with wires at the side or removed, trim 1mm off bulb terminals so it plugs in as far as possible. Swapping to this (bottom image)
