dashboard stud threads on S1 3.8
ysmalkie
Poland
#1 dashboard stud threads on S1 3.8
Post by ysmalkie » Wed Dec 22, 2021 1:37 pm
I have finally mounted the dashboard and am trying to fit the nuts but cannot find any that fit!..
Unless the cadmium process has thickened the studs, the studs are not #10 UNF as I thought.
They are not 2BA either, but they do seem to have 32TPI.
I have misplaced the set of nuts I had originally somewhere..
Can anyone give me a hint??..
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
tinworm
#2 Re: dashboard stud threads on S1 3.8
Post by tinworm » Wed Dec 22, 2021 3:52 pm
You can run a 5mm tap through some holes as the threads are the same pitch - slightly smaller core - and use 5mm
If desperate of course.
Barrie
ysmalkie
Poland
#3 Re: dashboard stud threads on S1 3.8
Post by ysmalkie » Wed Dec 22, 2021 9:01 pm
I am in no way desperate!! I think I am in 6th year of restoration, so I do have patience..
I am just wondering what thread it is BA or #10 or something else like BSF??..
Tadek
Tadek
Jaguar XK120 OTS
#4 Re: dashboard stud threads on S1 3.8
Post by Series1 Stu » Wed Dec 22, 2021 9:40 pm
They were definitely 10-32 UNF on my dash panels. Do you have a die you can run down the studs?
I'm pretty sure my dash panels were zinc plated and passivated although they were new for my left to right hand drive conversion.
ysmalkie
Poland
#5 Re: dashboard stud threads on S1 3.8
Post by ysmalkie » Wed Dec 22, 2021 11:02 pm
Many thanks Stu,
So was your dash panel original or a repro for the conversion?..
I do have a die I can use, I am just slightly reluctant to use it on a thread I am not too sure about...
Tadek
Tadek
Jaguar XK120 OTS
Allrand
#6 Re: dashboard stud threads on S1 3.8
Post by Allrand » Thu Dec 23, 2021 5:08 pm
Can't be 10-32, that's equal to 5-16. I found a 4 or 5mm fit perfectly on my 3.8.
Randall Botha
#7 Re: dashboard stud threads on S1 3.8
Post by Gfhug » Thu Dec 23, 2021 5:31 pm
10-32 thread is approx 4.8 mm diameter
https://en.wikipedia.org/wiki/Unified_Thread_Standard
#8 Re: dashboard stud threads on S1 3.8
Post by Series1 Stu » Thu Dec 23, 2021 7:37 pm
Tadek,
They are indeed 10-32 UNF. I've just checked my original LHD dash panels as well, just to be sure. I also noticed that the originals did not have a colour passivated layer so they may well be cadmium coated.
Randall
10-32 is not the same as 5/16! That nomenclature is used for sizes below 1/4". The 32 indicates 32 tpi. The major diameter is 0.190".
It definitely isn't a metric thread. Why would it be metric on a British built car of the 1960's?
Allrand
#9 Re: dashboard stud threads on S1 3.8
Post by Allrand » Fri Dec 24, 2021 4:55 am
Thanks for that info. In some metric domain countries like SA UNF threads are difficult to come by without costly & time consuming import orders. For those small sizes metric threads are often very close.
Randall Botha
ysmalkie
Poland
#10 Re: dashboard stud threads on S1 3.8
Post by ysmalkie » Fri Dec 24, 2021 12:59 pm
Many thanks Stu for confirming the thread size. Probably due to the size of the dash, much more cadmium accumulated then normally.
The dashes were (at least mine was) cad plated.
Merry Christmas to you all!
Tadek
Tadek
Jaguar XK120 OTS
