what shock?boge?
britannysmoosh
#1 what shock?boge?
Post by britannysmoosh » Thu Mar 31, 2011 6:31 am
hi guys..need help...BOGE shock, TOKICO,KYB or ????
which is the way to go for
great handling. Possibly w / 1+
lowering springs
Thanks..
*britanny
Post by Heuer » Thu Mar 31, 2011 9:54 am
Suggest you stick with standard Boge or Girling shocks. I tried Koni's but they did not suit the E-Type at all and I never got around to 'adjusting' them. Be careful if you are considering lowering the car as it already has limited ground clearance especially where speed bumps are concerned. I has 225/65 section tyres (another 1" lower than 185's) and lowered suspension, and whilst it looked good it was a pain to drive with constant grounding over undulating country roads:
Everything has now been put back to standard and the car is a delight to drive, much quicker across country and through towns.
38E
Post by 38E » Thu Mar 31, 2011 4:29 pm
I tried new regular shocks at first but was dissatisfied with their performance. I changed them for a set of Spax which are readily adjustable by means of a simple screw dial and improved te handling no end.
Be careful about lowering the car. Most modern tires will do that for you anyway. I run 205/70-15s which are already much lower than the original RS5s (or the later 185/78-15s).
Clive, 1962 Coupe 860320
(sold)
