rear window chrome trims
246GT
#1 rear window chrome trims
Post by 246GT » Sun Jan 09, 2022 7:28 pm
Hi has anyone had problems fitting the rear window chrome trims to the rubber, mine keep jumping out and seem not wide enough to stay in the rubber thanks ron.
Allrand
#2 Re: rear window chrome trims
Post by Allrand » Mon Jan 10, 2022 5:17 am
Yes I have the same problem, mine won't stay dowm in two spots, one at the top & one at the bottom. Probably the trim shape is not exact. Only solution is to glue it down, which I'm reluctant to do.
Randall Botha
246GT
#3 Re: rear window chrome trims
Post by 246GT » Mon Jan 10, 2022 9:52 am
hi yes i thought about gluing but not keen on the idea thanks for reply ron.
Dr.No007
#4 Re: rear window chrome trims
Post by Dr.No007 » Wed Jul 17, 2024 4:14 am
I am also interested in this topic as my FHC Series 1 has no chrome trim on the rear window. How exactly is the chrome trim attached? Directly on the window seal? Isn't there a filler strip that has to be inserted into the seal? Does anyone happen to have instructions for fitting it?
Thanks, Klaus
