P clip on vacuum tank to servo hose
Robbiee
#1 P clip on vacuum tank to servo hose
Post by Robbiee » Tue Jan 25, 2022 7:45 pm
Dear all
Please could someone tell me where the Pclip on the hose that takes vacuum from the reservac tank to the Kelsey hayes servo is attached?
Robbie
Allrand
#2 Re: P clip on vacuum tank to servo hose
Post by Allrand » Wed Jan 26, 2022 4:47 am
Never knew there was one.
Randall Botha
Robbiee
#3 Re: P clip on vacuum tank to servo hose
Post by Robbiee » Wed Jan 26, 2022 6:47 am
I’m pretty sure I’ve seen a photo somewhere of where it goes but I just can’t find it!
It’s on page 117 of the spare parts catalogue
One only on RHD car
Robbiee
#4 Re: P clip on vacuum tank to servo hose
Post by Robbiee » Wed Jan 26, 2022 7:30 am
I’m thinking maybe it goes here??
#5 Re: P clip on vacuum tank to servo hose
Post by rswaffie » Wed Jan 26, 2022 8:28 am
Hi Robbiee
There was one on my LHD 3.8, but I think it was for routing of a different hose/cable - possibly the speedo?
Here it is during the restoration as I left it in situ when I converted to RHD.
#6 Re: P clip on vacuum tank to servo hose
Post by rswaffie » Wed Jan 26, 2022 9:38 am
And from the factory fit section, a lhd car….
Robbiee
#7 Re: P clip on vacuum tank to servo hose
Post by Robbiee » Wed Jan 26, 2022 11:43 am
Yes…there are 3 p clips on LHD but the orientation is different as the vacuum has to come from the tank on the opposite side of the car!
The RHD has only one P clip and I believe it helps hold the vacuum hose down against the left hand side of the master cylinder housing
I’m sure someone will have a picture!!
Philk
#8 Re: P clip on vacuum tank to servo hose
Post by Philk » Wed Jan 26, 2022 1:28 pm
This picture is the clip for Speedometer cable (LHD) and keeps it angled correctly. I'd have to check on the P Clip location for the vacuum hoses.
1964 S1 3.8 OTS
ysmalkie
Poland
#9 Re: P clip on vacuum tank to servo hose
Post by ysmalkie » Fri Jan 28, 2022 2:21 pm
LHD car:
Not sure about the RHD..
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
Robbiee
#10 Re: P clip on vacuum tank to servo hose
Post by Robbiee » Fri Jan 28, 2022 4:58 pm
Thanks Tadek
That looks good for LHD
I reckon the RHD one goes as in my picture below
It seems to make the pipe curve correctly
Robbie
ysmalkie
Poland
#11 Re: P clip on vacuum tank to servo hose
Post by ysmalkie » Sat Jan 29, 2022 6:42 pm
You reminded me that I need a hose clip there!
Thanks! :-)
Tadek
Jaguar XK120 OTS
Robbiee
#12 Re: P clip on vacuum tank to servo hose
Post by Robbiee » Sat Jan 29, 2022 9:44 pm
Hi Tadek
Is yours RHD?
Allrand
#13 Re: P clip on vacuum tank to servo hose
Post by Allrand » Sun Jan 30, 2022 11:00 am
Thanks! :-)
Same here, interesting detail, thanks.
Randall Botha
Robbiee
#14 Re: P clip on vacuum tank to servo hose
Post by Robbiee » Sun Jan 30, 2022 12:10 pm
Only on this forum could we all find the position of single P clip “interesting”😂
I’m not even sure that I’ve got it under the correct nut!!
Does anyone think it should go on the one above instead??
Some nerdy chap out there must know
Robbie
