Post
by Geoff Allam » Mon Jan 31, 2022 9:32 pm
Hi Colin. Yes, there have been a number of discussions about these gaiters over the years. I do not know if there is a specific range of cars that got these gaiters. What year is your car. Mine is a late 1967. The gaiter on mine is still intact and if I can get the splines apart without damaging it I will reuse it. Yours is obviously not salvageable. I would make a circular cut around it and remove the torn part but retain the solid section. A section of bicycle inner tube could then be bonded to the solid section and attached to the other piece of propshaft with a cv boot clamp. I would guess that a tube from one of the fat tire bicycles or even a small motorcycle would fit reasonably. The other option would be to remove the whole piece of the original gaiter and attach the tube to both ends of the propshaft with clamps.
Geoff Allam
