Bulkhead diagram with mounting labels
jcarey
Topic author - Posts: 12
#1 Bulkhead diagram with mounting labels
I posted this on the Jag-Lovers E-type forum and was asked by Steve to post it here. I made this based on a diagram John North created and I found on the Internet while restoring my 1963 Coupe. I expanded on it in an attempt to label every opening and threaded opening in the bulkhead/bodywork and what each is used for. I am sure errors may be present, so please double check my work before committing to anything irreversible. Best regards.
- Attachments
- Firewall.jpg (146.94 KiB) Viewed 21812 times
Bettie IV my 1963 S1 E-Type FHC (888373)
#2 Re: Bulkhead diagram with mounting labels
Thanks John....im sure it will be of intetest to the forum
#3 Re: Bulkhead diagram with mounting labels
Thanks for posting, one initial observation is that you have the holes used for the brake vacuum pipes (lower ones) labelled as "coolant tubes"
#4 Re: Bulkhead diagram with mounting labels
The '???' On the bottom line are for the choke cable grommet on a S1 car blanked off on twin carbs. Not sure the 'rust prevention blanks' are standard.
Angus 67 FHC 1E33656
61 OTS 875047
61 OTS 875047
#5 Re: Bulkhead diagram with mounting labels
That's a great piece of work. Is there a version available that could be amended to the later revised bulkhead?
-Mark
jcarey
#6 Re: Bulkhead diagram with mounting labels
Simon,288gto wrote:Thanks for posting, one initial observation is that you have the holes used for the brake vacuum pipes (lower ones) labelled as "coolant tubes"
Your correction will be added to my diagram asap! Thanks.
jcarey
#7 Re: Bulkhead diagram with mounting labels
Angus,1954Etype wrote:The '???' On the bottom line are for the choke cable grommet on a S1 car blanked off on twin carbs. Not sure the 'rust prevention blanks' are standard.
Thanks - I'll add the choke cable grommet label to this point of my diagram. I only had one example to work with at the time and it was my 1969 FHC. It's certainly possible these rust proofing plugs were added after the factory shipped it to the Northeastern USA.
jcarey
#8 Re: Bulkhead diagram with mounting labels
Here is an updated version with your input
thanks,
thanks,
- Attachments
- Firewall 2-2-2017-smaller.jpg (254.24 KiB) Viewed 21650 times
#9 Re: Bulkhead diagram with mounting labels
John, that's a very useful diagram. Is it possible to get a higher resolution copy?
Maybe David (Heuer) could add that to the knowledge base?
Oh, and as Mark asked earlier, is there a version for the later cars?
#10 Re: Bulkhead diagram with mounting labels
Done!Gfhug wrote: Maybe David (Heuer) could add that to the knowledge base?
#11 Re: Bulkhead diagram with mounting labels
Speedo cable?
Unless it's labelled differently.
1965 Series 1 4.2 FHC
#12 Re: Bulkhead diagram with mounting labels
Do the "three holes" on LH and washer bottle on RH alternate for LHD and RHD ?
#13 Re: Bulkhead diagram with mounting labels
They do on my car.Do the "three holes" on LH and washer bottle on RH alternate for LHD and RHD ?
jcarey
#14 Re: Bulkhead diagram with mounting labels
I have the original file and could make a higher res version for you if you like - but I'd need to send it to you via email I think. I will send a PM asking for your email OK? I don't have one for later version cars.Gfhug wrote:John, that's a very useful diagram. Is it possible to get a higher resolution copy?
Heuer,
If you would like to have a high res version for the knowledge base, let me know and we can exchange emails too.
Cheers,
#15 Re: Bulkhead diagram with mounting labels
PM Sent. I'd like to adapt it for the S2.
-Mark
#16 Re: Bulkhead diagram with mounting labels
Hi all
I’m planning to do a RHD version of the bulkhead diagram for 3.8 car
Anyone interested?
Robbie
Anyone interested?
Robbie
#17 Re: Bulkhead diagram with mounting labels
Hi Robbie...Im sure it will be of great use and good to add to the knowledge base....Steve
#19 Re: Bulkhead diagram with mounting labels
Great idea and will be much appreciated.
1965 S1 4.2 FHC (early)
#20 Re: Bulkhead diagram with mounting labels
Welcome here
