Speedo Cable through the bulkhead
ChrisC
#1 Speedo Cable through the bulkhead
Post by ChrisC » Sun Apr 10, 2011 11:17 am
Folks,
Can anyone tell me which bulkhead hole the speedo cable goes through?
Is it the one next to the steering column or the one on the side of the transmission tunnel?
1964 FHC 4.2
Post by PeterCrespin » Sun Apr 10, 2011 11:55 am
It's the largish one directly behind the, err, speedo in the bulkhead.
There are always two for LHD/RHD with a blanking grommet for the unused one. Any number of pics on xkedata.com.
ChrisC
Post by ChrisC » Sun Apr 10, 2011 12:15 pm
thanks Peter but a little more information would help. I have 4 holes "behind the speedo" in the bulkhead 3 of which are "largish".
Would some kind person pop out to their car and let me know which one of the following it is?
1. at the top of the bulkhead above the steering column
2. slightly to the left of the steering column
3. slightly to the right of the steering column (and on the same panel)
4. on the transmission tunnel
1964 FHC 4.2
andrewh
Post by andrewh » Sun Apr 10, 2011 9:48 pm
this is on a 3.8 but it may be the same as a 4.2 I imagine. Hope it helps
1962 3.8 Series One FHC
ChrisC
Post by ChrisC » Sun Apr 10, 2011 10:17 pm
thanks Andrew. So what is the cable coming out slightly to the right of the steering column? Is that the choke cable?
1964 FHC 4.2
andrewh
Post by andrewh » Mon Apr 11, 2011 8:09 am
I will need to check that on the car so will post later on.
Post by Heuer » Mon Apr 11, 2011 8:14 am
Chris
Not sure if it will help but have a look at the LHD to RHD conversion guides in the Knowledge Base as there are a lot of photos detailing the bulkhead, for obvious reasons. http://etypeuk.com/forum/viewtopic.php?t=1664
andrewh
Post by andrewh » Mon Apr 11, 2011 9:40 am
indeed you are correct , that is the choke cable. Good luck
ChrisC
Post by ChrisC » Mon Apr 11, 2011 9:47 am
Great thanks Andrew. That removes one of the options through the bulkhead.
1964 FHC 4.2
