I’ve noticed my SU carbs don’t have the correct overflow pipes that feed fuel to below. The rear carb has one that appears ok, the middle seems to have a crimp in it that would prevent fuel flowing through and the front has been cut off and crimped about an inch from the float lid. And I only have (overflow) holes in the top of the rear and centre float lids, not the front. One thing that may explain the difference is that the rear has a AUD112R tag, the centre a AUD112F, and the front has no tag. Maybe a twin carb set up converted to 3?
So I’m assuming I need to buy the correct overflow pipes but should I also be changing the front float lid for one with a hole
Centre:
Front:
Rear:
