Post
by Threadbear » Tue Jul 30, 2019 5:27 pm
I have read the posts on here as I was looking for a battery for my '68 car, and thought I would offer my up to date info, which really just backs up what has gone before. I managed to get in touch with John Burton, via the JDC magazine contact info. He is still able to supply, from stock, a battery which is black, "rubber" case and is fitted with 13 plates per cell. He can supply with the terminal posts either way round, so as to suit various models. It is sealed, so shouldn't leak and the cost is a very reasonable £95. For US owners, it is made by a US company called Voltex so should be available there also, and looks like they may have a plant in Aus too. One very minor problem was that I had to trim some small ribs on the corners to allow the steel clamp ring to sit nicely, but this just took a couple of minutes, and is hidden by the ring anyway. This is the 4th battery my car has had in 51 years, and part of the secret to that is to fit a battery cut off switch, and use it every time the car is garaged. After all, in the UK you never know when the next dry day is coming to bring it out again!
Hope this helps!
