Well The Guy Broad box has arrived.My threads are usually started and completed in two days
Once we get going I will detail step by step .
Let’s reserve politics and brand boxes once the final verdict and test drives are done.
I’ve had them all…..so banter on quality and no return phone calls will be for another time.
Just sticking to the swap!
So
I had a custom drive shaft made brand new.
New u joints greased and all
The original bell housing is used.
My one piece light weight flywheel is reused but sending back to CJ to rebalance with the Guy Broad clutch.
I’m dropping the unit from below .
Transmission breather pipe is moot.
Original rear spring mount is moot.
The trick rear mount is of Aston DB design with twin rubber bushes , more stability .
They say my stock throw out bearing is best so I just ordered a new one.
This should be fun guys
Stay tuned!!!
Gtjoey1314
