Servo Reservoir / Heater Box
colinevans
#1 Servo Reservoir / Heater Box
Post by colinevans » Wed Jul 13, 2022 12:25 pm
Hi Guys
A couple of quick questions as I have lost some of my pucs taken during the stripdown. Can anyone send me a good pic showing where the reservoir for the servo clamps to on the near side? Also what are the 3 lugs for that come off the bottom of the heater assembly for (see pic)?.
Cheers, Colin.
Colin
Series 2 OTS, 280SL
Monkeyfinger
#2 Re: Servo Reservoir / Heater Box
Post by Monkeyfinger » Thu Jul 14, 2022 9:31 am
Colin, attached are some pics from my car - not sure what you need to see for the servo but hopefully these will help. Your heater motor doesn't look original, but my original has three similar lugs. I happen to have a cable routed through one lug, but I doubt they have any real purpose on an E type and maybe it was a standard motor that Jaguar used?
colinevans
#3 Re: Servo Reservoir / Heater Box
Post by colinevans » Thu Jul 14, 2022 9:53 am
Hi Richard, thanks for that, it’s what I guessed on the heater. On the servo, what I could really do with a pic of is where the fluid reservoir is mounted. I’m not sure if it’s on the mudshield somewhere, an image would definitely help here.
Many thanks, Colin.
Colin
Series 2 OTS, 280SL
Monkeyfinger
#4 Re: Servo Reservoir / Heater Box
Post by Monkeyfinger » Thu Jul 14, 2022 10:09 am
Ah, that's an easy one...there's a bracket between washer bottle and the heater box.
Also - since you also have a roadster, have you seen my post this morning ? If you are able to check a dimension for me, it would be a big help...understand if that may not be possible for you right now.
colinevans
#5 Re: Servo Reservoir / Heater Box
Post by colinevans » Thu Jul 14, 2022 10:27 am
Thanks Richard, so that bracket screws to the bulkhead plate?
I’ll try and source one from one of the usuals.
Colin
Series 2 OTS, 280SL
Monkeyfinger
#6 Re: Servo Reservoir / Heater Box
Post by Monkeyfinger » Thu Jul 14, 2022 10:35 am
Looks like the bulkhead blanking plate has an upstand welded to it.
colinevans
#7 Re: Servo Reservoir / Heater Box
Post by colinevans » Thu Jul 14, 2022 10:38 am
Thanks, that’s helpful Richard.
Colin
Series 2 OTS, 280SL
