Master Brake/ Clutch Cylinder Aluminium Tags
#1 Master Brake/ Clutch Cylinder Aluminium Tags
I have just had a batch of 50 Aluminium tags cut. The dimensions were taken from an original 1961 tag that is in very good condition. I am awaiting delivery of the correct size number and letter punches and have to make a punching jig. If any forum members are interested please let me know, I will not be putting them on eBay etc. I have had them made for my car but the minimum quantity was 50 hence the spares. I do not yet know the cost as I am expecting the letter and number punching to be rathe fiddly.
Keith Walker
Jan 1962 FHC
Jan 1962 FHC
#2 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Interesting🤨
#3 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Up to which year/car no were they fitted?
Randall Botha
#4 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Yes Please - two of these for my brake cylinders. There is a very useful article (post #66 on the 3.8 Factory Fit section) showing what stamping is required. viewtopic.php?f=4&t=2006&p=39720&hilit=tag#p39720. There are two different part numbers for each of the brake master cylinders which are then date coded. Would you potentially offer these for different years?
I am not sure whether the clutch master cylinder had the same type of tag though. If it is, could you please add another one for that.
1964 S1 3.8 OTS
1964 S1 3.8 OTS
#5 Re: Master Brake/ Clutch Cylinder Aluminium Tags
If be interested in a couple
Robbie
Robbie
#6 Re: Master Brake/ Clutch Cylinder Aluminium Tags
I'd be interested in 3 (2xbrakes,1clutch).
Randall Botha
Geoff Allam
#7 Re: Master Brake/ Clutch Cylinder Aluminium Tags
I would also be interested in 3.
Geoff Allam
#8 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Two here please (2).
Apprentice Engineer
#9 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Yes - I am interested in two for the brake cylinders and one for the clutch cylinder.
Many thanks.
Many thanks.
#10 Re: Master Brake/ Clutch Cylinder Aluminium Tags
4 brake and
2 clutch
please
2 clutch
please
#11 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Hi Maikel, you're the originalty guru, did all 3. 8's have the MC tags?
Randall Botha
#12 Re: Master Brake/ Clutch Cylinder Aluminium Tags
I would be interested in three please.
Mike
Mike
Slipstream
#13 Re: Master Brake/ Clutch Cylinder Aluminium Tags
As to how long the tags were on, my 1967 ots (1E15221) has one.
Bob
1967 E Type OTS
2002 Honda S2000
1967 E Type OTS
2002 Honda S2000
#14 Re: Master Brake/ Clutch Cylinder Aluminium Tags
That's useful info Bob.
Randall Botha
Ruurd Schut
#15 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Nice !
If possible I would like to have 3 pcs. for my early 3.8
Thanks,
Ruurd
Thanks,
Ruurd
#16 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Me too…….x2 for brakes and clutch as well if that’s period correct for early ‘63
#17 Re: Master Brake/ Clutch Cylinder Aluminium Tags
If possible….i.d be glad to have 3 of them
#18 Re: Master Brake/ Clutch Cylinder Aluminium Tags
And a set of 3 for me too please
Darryl
#19 Re: Master Brake/ Clutch Cylinder Aluminium Tags
I’ll take a set of three for my ‘64 E-type 3.8 please.
Many thanks,
Alan
New Jersey, USA
Many thanks,
Alan
New Jersey, USA
SpeedieJag
#20 Re: Master Brake/ Clutch Cylinder Aluminium Tags
Hi, I'll like a set of three for my car - two brake, one clutch.
Thanks,
James
Fullerton, CA USA
Thanks,
James
Fullerton, CA USA
James
1965 E-Type S1 OTS
2020 F-Type R Coupe
1965 E-Type S1 OTS
2020 F-Type R Coupe
