The 5 Speed is here……..
#101 Re: The 5 Speed is here……..
Exciting times!!!!
I agree and this car is bone dry
After the call I might just do it so I have the room.
Gtjoey1314
Gtjoey1314
#102 Re: The 5 Speed is here……..
New week….
Calling Guy Broad today….
Bellhousing gasket needed?
Crossbar message needed?
8th bolt hole needed on casing?
Speedo cable install before placing in?
Calling CJ……
Lightweight flywheel still good after 9,000 miles and beating off crank?
Balance flywheel with new clutch
Send back with alignment tool.
Oh and take time out to drive what should be delivered today baby!!!
Look close
Calling CJ……
Look close
#103 Re: The 5 Speed is here……..
Looking good Joey. That E type of yours is fantastic. Dont forget the engine goes backwards and forward quite a lot on an E type, useful to know for fitting the reaction plate.
I was thinking of you the other day in France.
Loads of GT40s at the Le Mans Classic. The 2005 ish ones look good value in the US @ around $300k, however import duty and VAT for UK import is a KILLER.
I want one. Need to get the money!
Not selling any Jags to do it though, no way! Jags rule!
#104 Re: The 5 Speed is here……..
It’s the good life!
When Chris and I drove Vin 360’around the world we ended up at that event !
That was 10 years ago my friend!
Climbing Stelio
Climbing Stelio
#105 Re: The 5 Speed is here……..
Great news......
Tom at Guy Broad is a GREAT GUY!
All of my questions answered as long as the car is in line
Im going to massage the crossmember on wednesday.
Next the eight bolt is deleted for clearance.
Speedo cable is a toss up before or after........
Grease spline and pilot bush tip with GRAPHOGEN, Anyone use anything else?
Pictures to come soon....
The clutch and flywheel are sent and should have news soon as well.
Great stuff!
GTJOEY1314
Great stuff!
GTJOEY1314
#107 Re: The 5 Speed is here……..
The 575m will be here tomorrow or the next day.
1 owner 10,000 miles......
Its so pretty.
I will buy and sell , trade cars forever, My ETYPE I will be buried in!
GTJOEY1314
Its so pretty.
GTJOEY1314
#108 Re: The 5 Speed is here……..
Tonite we are jumping on the actual transmission!!!!
Got my questions answered so hold on tight till tonite!
We can assemble the bell housing and show what is needed
Gtjoey1314
And what we can delete
Gtjoey1314
#109 Re: The 5 Speed is here……..
Let’s do it…..
The transmission is completely converted with the exception of fluid.
Let’s review
The bell housing is used from my original 4.2.
The inner dust seal is removed as per Guy Broad.
Once punched out , raise the base of the unit and the old bellhousing just slides over the unit which had studs installed.
It’s very clean and neat!
NO in between gasket is needed between the casing and bellhousing because this is a sealed unit.
Next comes the clutch fork.
I personally waterproof grease the shaft and mark it so when you tap it back in it lines up with the lock in Allen key stud! It then has a lock nut and washer to keep in place.
Follow the pictures
Any questions just post!
Tonite hopefully we get to the crossmember
Enjoy!
Rubber hose protecting threads from supplier
Let’s review
Follow the pictures
Enjoy!
#111 Re: The 5 Speed is here……..
Note eighth hole purposely left out for the amount of fork throw!
I can’t help why pics are out of order but you get it
#112 Re: The 5 Speed is here……..
I took shot of pin NOT lined up look close
You turn the pin till you see the hole
Then the stud will screw into the opening
Then use lock nut and washer!
#114 Re: The 5 Speed is here……..
You guys having fun?
Post away!
Gtjoey13-4
Post away!
Gtjoey13-4
#115 Re: The 5 Speed is here……..
Just got home….
The directions say
5 inches wide, 1 inch down and 1 inch back.
The goal here is to make 1 perfect cut, flip it to invert
Weld it nice then bury it in paint and undercoating!
We shall see …. Give me a bit.
Gtjoey1314
#116 Re: The 5 Speed is here……..
looks great can't wait to see it back on the road.
#120 Re: The 5 Speed is here……..
Great progress Joey
You going to the show in Stony Brook this Saturday?
