Delayed Oil Pressure On Startup
#1 Delayed Oil Pressure On Startup
I have just finished the restoration on my 1967 series 1 OTS. The engine was completely rebuilt with a new oil pump. However I have noticed that after the car has been standing for a few hours there is a delay on startup of about 3 seconds before the oil light goes out. I think this is a little too long? If I stop the engine and immediately restart the light will go out straight away.
I just like to get a little feedback on whether this is normal.
#2 Re: Delayed Oil Pressure On Startup
I don't have a light but I have 4 cars with XK engines. In all of them it takes 5 to 10 seconds before oil pressure comes up on the gauge.
#3 Re: Delayed Oil Pressure On Startup
The gauges work on the basis of thermocouple and it takes time for the metal to heat up.
#4 Re: Delayed Oil Pressure On Startup
I have a separate light to my gauge and when starting with 3/4 choke the light extinguishes pretty quickly and approx. 1-1.5 seconds after it fires.
1965 S1 4.2 FHC (early)
#5 Re: Delayed Oil Pressure On Startup
I think you mean bimetal based, where the bimetal in the gauge deflects in proportion to the current supplied by the sender.
Thermocouples are an electrical junction of 2 dissimilar metals generally used to measure temperature.
It's a commonly made mistake so no big deal.
#6 Re: Delayed Oil Pressure On Startup
#7 Re: Delayed Oil Pressure On Startup
Newly rebuilt engine.....what pressure is your pressure switch rated at....genuine part or after market....you need a mechanical oil pressure guage to see whats really going on....without one its just speculation..what your seeing isnt really abnormal as far as im aware.......Steve
#8 Re: Delayed Oil Pressure On Startup
#9 Re: Delayed Oil Pressure On Startup
Am I the only one asking “oil light? On a 67 4.2?” Mine doesn’t have an oil light.
#10 Re: Delayed Oil Pressure On Startup
Perhaps he's thinking the alternator light is for oil pressure?
#11 Re: Delayed Oil Pressure On Startup
The poster is in Canada...a 67 registered car there could be a 66 build in UK....poster says he has an oil pressure lamp....he could even have an after market fitting...Steve
