The 5 Speed is here……..
BobKTX
#521 Re: The 5 Speed is here……..
Post by BobKTX » Mon Oct 24, 2022 10:38 pm
gtjoey wrote:
Mon Oct 24, 2022 2:46 pm
Thanks DWW….
I’m working with Kirk to post a video soon at driving speed and ratios!
Thanks again
I called Guy Broad and told them
I’ll call in 4 years when I do 100,000 miles on the new box👍🏾
Gtjoey1314
Send me the video and I'll post it. Great job and great advice!!!
gtjoey
#522 Re: The 5 Speed is here……..
Post by gtjoey » Tue Oct 25, 2022 11:08 am
I have my phone set with the speedometer app.
My Speedo is off 10 mph because I originally was going to a 288 rear with the 4 speed at the time.
So here we go.......If it stops raining I will post a video or videos through Bob .
Stats
MICHELIN XWX TIRES 70/205/15
SET AT 30 LBS
6 INCH MWS TRIPLE LACE COMP SPOKE WHEELS
GAZ SUSPENSION ALL AROUND SET AT NUMBER 2
RIDE HEIGHT SET AT 16 INCHES ON THE DOOR SILL
GUY BROAD BOX WITH 5TH GEAR AT 0.763.1
REAREND 307
IGNITION 1 2 3 SET AT NUMBER 2 FOR ADVANCE
I dont think there is much more to add.
Stay tuned.
GTJOEY1314
gtjoey
#523 Re: The 5 Speed is here……..
Post by gtjoey » Tue Oct 25, 2022 11:21 am
Found this ,should be close,maybe explains why my second and third I can drive around town without looking for the next gear.
4.2 original syncro box 1967
1st 2.68
2nd 1.74
3rd 1.27
4th 1-1
GUY BROAD
1ST 3.31:1
2ND 2.08:1
3RD 1.36:1
4TH 1:1
5TH 0.763:1 AHHHHHHHH
Reverse 3.26:1
gtjoey
#524 Re: The 5 Speed is here……..
Post by gtjoey » Tue Oct 25, 2022 11:26 pm
Now! It’s all done ….
LED lights , console in and the NEW , SNG ledger bar is ten times better then their last repro!
Enjoy guys! Videos soon!
gtjoey
#525 Re: The 5 Speed is here……..
Post by gtjoey » Wed Oct 26, 2022 6:42 pm
This weekend I will hit the 1,000 mile mark!
It’s a shame but Someone has to do it!😀
Gtjoey1314
#526 Re: The 5 Speed is here……..
Post by DWW » Wed Oct 26, 2022 11:11 pm
I feel for you bro :bigrin:
Allrand
#527 Re: The 5 Speed is here……..
Post by Allrand » Thu Oct 27, 2022 6:28 am
Tough. 😀
Randall Botha
gtjoey
#528 Re: The 5 Speed is here……..
Post by gtjoey » Thu Oct 27, 2022 10:17 pm
To Really button up the job
I have trusted Rob Beeres with many upgrades that never fail, SO far.
Here is one that should wrap up the suspension
7/8th front sway bar
Stock in the rear
Just to take out the float in the turns
#529 Re: The 5 Speed is here……..
Post by Heuer » Fri Oct 28, 2022 11:19 am
Yes, I have used the thicker S3 torsion (sway bar) on the front of my OTS for years. Works really well on Alpine passes.
Phil P
#530 Re: The 5 Speed is here……..
Post by Phil P » Fri Oct 28, 2022 7:33 pm
Hi Joey,
Thanks for your great blog which I've followed throughout.
Let us know if the thicker front sway bar increases understeer and has the results you're looking for.
From your ratios for the five speed, they look to be shorter in first, second and third than the original.
Yours,
Phil P
1965 4.2 FHC
gtjoey
#531 Re: The 5 Speed is here……..
Post by gtjoey » Fri Oct 28, 2022 7:36 pm
Well
Alpine passes maybe we go😃!!!
Just installed the bar.
With the gas adjustable bumped up one turn to 3.
The sway bar makes the turns soooooo flat.
Great Great Great addition!
It’s the quality of the parts once again
Poly bushes with a collar so now the bar and dog legs DONT clunk!
This thing might be going on a world trip!
The New sweet spot is 60 in 5th at 2,000 rpm on the nose
It’s a Lexus it’s so quiet but Strong not bogging.
Tomorrow I get the Mangoletsi kit but that’s another thread👍🏾
The transmission and full stats once the car is agligned
gtjoey
#532 Re: The 5 Speed is here……..
Post by gtjoey » Sat Oct 29, 2022 7:49 pm
Update
60 at 2,000 rpm is such a sweet spot!
Great times ahead
Gtjoey1314
gtjoey
#533 Re: The 5 Speed is here……..
Post by gtjoey » Sun Oct 30, 2022 9:26 am
Just dialing in the shocks then alignment
Then the video
gtjoey
#534 Re: The 5 Speed is here……..
Post by gtjoey » Tue Nov 01, 2022 11:08 am
I tell you one thing .....with the 5 speed the car eats NO gas!
60 at 2,000 rpm all highway long the needle never moves....I thought I blew a fuse :bigrin:
gtjoey1314
ralphr1780
#535 Re: The 5 Speed is here……..
Post by ralphr1780 » Wed Nov 02, 2022 7:35 pm
Guess we all did blow a fuse :lol:
Ralph
'69 OTS + '62 OTS - Belgium
#536 Re: The 5 Speed is here……..
Post by Heuer » Wed Nov 02, 2022 7:40 pm
gtjoey1314
Clearly you are not driving it properly! Call yourself Italian :lol:
I was getting 14mpg driving with spirit through France, 23.5 when driving on the Autoroute at 150kph. This with 2.88 different on 5 speed. :bouncyyellow:
gtjoey
#537 Re: The 5 Speed is here……..
Post by gtjoey » Thu Nov 03, 2022 11:28 am
If your at 23 at 150 klm
With my 307 I have to be in the same range at 90 mph
Once in a blue moon I downshift just to gt the revs up NEAR 3,000!
Just to clear the plugs but even that is not needed
Having fun…..
Gtjoey1314
#538 Re: The 5 Speed is here……..
Post by mgcjag » Thu Nov 03, 2022 12:13 pm
Dont forget that unlike most things from the US that are bigger....our UK gallons are around 20% larger than US gallons.......Steve
montauk1989
#539 Re: The 5 Speed is here……..
Post by montauk1989 » Wed Nov 09, 2022 5:02 pm
Joey,
How many "clicks" total on your shocks? On all six of my Gaz shocks, there's 19 clicks from mild to firm. I've got them set at 10 clicks up from mild.
I also set the rear springs so that I had 22" on the left rear arch. I then set the right rear springs to the same dimension measuring about 3" from the center of the lower shock bolt to the bottom of big adjustable collar. With all four shocks set the same, the right rear is about 22 1/2". Front left is 23" and front right is 23 1/2". I haven't touched the torsion bars so they're probably set as they were when new.
So the right side is 1/2" taller than the left but I plan to drive it around a bit more before any more adjustments are made to see if anything settles in. I doubt it will but worth a shot.
The car feels much more planted than the way I had it set up before. I had the rear springs and all six shocks set way too soft.
montauk1989
#540 Re: The 5 Speed is here……..
Post by montauk1989 » Wed Nov 09, 2022 5:29 pm
Never mind I just found this thread
viewtopic.php?f=3&t=19353
