Oil return hose
No Quarter
Topic author - Posts: 289
#1 Oil return hose
I have a perhaps small problem with potentially pretty serious consequences. The oil hose from the filter unit down to the oil pan, which is supposed to contain hot oil. My problem is that the two studs are not the same OD. The top one is OD 15.8mm, the lower is OD 14.3mm. My local parts guy sold me a hose that's very soft and flexible, and that can fit both ends. But it being so soft, do I trust it with hot oil? Limora sold me a thick stiff hose that fit on top, but is too big for the lower stud. And a third hose I got fits below, and can with great force be slided onto the top stud, but the hose then looks like a problem waiting to happen.
Am I too cautious? Is it correct to have different size studs? Or?
Mikael
Author of "Tuning Made Easy"
#2 Re: Oil return hose
Not 100% sure but from what I can see the hose is of uniform diameter of the larger and the smaller ID gets a jubilee clamp.
#3 Re: Oil return hose
The correct hose is tapered...different internal diameter at each ends.....they are available....but most of the usuals supply a straight hose.....if you use straight then at least make sure its suitable for oil and not a coolant hose......Steve
#4 Re: Oil return hose
Yep, one of those Jaguar mysteries that we will never solve! The original hose was indeed tapered so unless you can find a supplier (I only know of one and they do not sell direct) it is a matter of tightening the lower clamp until there are no leaks.
#5 Re: Oil return hose
Just use two Jubilee Clips on the curved sump pipe.
One to seal around just under the top flared pipe diameter and another below to tighten on the lower smaller pipe diameter. The other smaller pipe attached is the Header Tank overflow pipe.
This the heavy pretty inflexible oil pipe from SNG Barrett with the white printed oil specification on the pipe hidden around the back.
No leaks from the sump or this sump return pipe !
Dave Rose
1967 Series 1 4.2 FHC
#6 Re: Oil return hose
What I do is cut a short length of narrower ID hose (I use clear PVC) and slide this over the smaller spigot on the sump.
Then you can use the straight hose and it doesn't leak.
As to whether the hose supplied to you is safe I can't comment. Ask the seller if it is oil compatible.
#7 Re: Oil return hose
A good auto parts store will have hose for carrying hot oil. There is no pressure there.
If you can't find one go to a shop that does hydraulic hose and fittings. They make up hydraulic pressure lines and will surely have what you need.
Layne
Car #876005, 62 OTS
Car #876005, 62 OTS
#8 Re: Oil return hose
An elegant and long term solution, due to the hose construction. A bit pricey at $30 before shipping, though.
http://www.classicjaguar.com/cj/111414sh1.jpg
#9 Re: Oil return hose
1967 S1.25 OTS, 1952 MG TD
#10 Re: Oil return hose
Hopefully on Julian’s (SNGB UK) radar as I would like one of these soon.bitsobrits wrote: ↑Thu Jun 08, 2023 11:56 pmAn elegant and long term solution, due to the hose construction. A bit pricey at $30 before shipping, though.
1965 S1 4.2 FHC (early)
#11 Re: Oil return hose
Plenty of hose manufacturers that can make you one..or check out ebay..silicone hose reducers...iv just got 2 larger diameter coolant hose reducers for a project...Steve... like this
just choose your size https://www.ebay.co.uk/itm/Black-Silico ... 635-2958-0
#12 Re: Oil return hose
Check a racing supply shop. Over here Pegasus Racing stocks silicon hose with differentially sized ends.
Layne
Car #876005, 62 OTS
Car #876005, 62 OTS
#13 Re: Oil return hose
Perfect, thanks gents.
No Quarter
#14 Re: Oil return hose
I ended up using the Limora hose. It says oil on it, it's stiff, thick and confidence inspiring, it fits perfectly on top, and with a gap at the bottom of course. But with two clamps tightened at the bottom, I was not able to turn the hose by hand, so pretty tight.
I'll keep an eye on it...
Thanks to all
Thanks to all
Mikael
#15 Re: Oil return hose
Sounds good shouldn't give any problems.
#16 Re: Oil return hose (Oil Pressure Relief Valve Bleed Hose C15949)
The correct double-diameter hose from the relief-valve down to the sump pipe is available from Angus Moss.
https://www.mossjaguar.com/index.html
He's far too posh to have a mail-order web-site BUT if you're polite he will sell you one.
With a wipe of sealant just under the flare, and just one hose-clip, mine has been drip free.
