Garage Floor Tiles
ALAN COCHRANE
#1 Garage Floor Tiles
Post by ALAN COCHRANE » Tue Jul 04, 2023 12:48 pm
Hi Everyone
Looking for advice on floor tiles for my new garage. I'm intending to fit non slip interlocking tiles over the concrete. I would need them to be oil resistant and strong enough to support axle stands and the like. The floor area is approximately 52sq m.
Thanks in advance
Alan Cochrane
Monkeyfinger
#2 Re: Garage Floor Tiles
Post by Monkeyfinger » Tue Jul 04, 2023 2:01 pm
I used these:
https://duramat.co.uk/
No issues with normal garage activities on these, and they look great.
#3 Re: Garage Floor Tiles
Post by Gfhug » Tue Jul 04, 2023 4:35 pm
Can you easily use axle stands and trolley jacks on them? Or do they leave significant dents and not roll well?
Thanks, Geoff
#4 Re: Garage Floor Tiles
Post by Heuer » Tue Jul 04, 2023 6:50 pm
Jack stands do not make any significant Mark's but tyres do. Black from the rubber leaches out and stains the tile and it almost impossible to remove.
Oil will also stain the tiles over time and I have a major problem following an over winter oil leak. The oil has seeped between the joints and travels along them. It also pools under them and the only way to get rid of it is to lift the tiles. Ditto coolant or any fluid. I have bought an industrial floor cleaner which does a decent job but stains remain. I have had the tiles down for about 15 years so I guess they need replacing. I will post some photos tomorrow.
#5 Re: Garage Floor Tiles
Post by rswaffie » Tue Jul 04, 2023 10:37 pm
I also used Duramat - black checker plate with yellow ramp edging. Had the car up on axel stands, jacks and hydraulic ramps with no issues. Any oil or fluids cleaned up ok with engine degreaser, but were cleaned up immediately so I can’t comment on prolonged exposure. Easy to fit and cut.
#6 Re: Garage Floor Tiles
Post by abowie » Tue Jul 04, 2023 11:14 pm
I used epoxy concrete paint.
Tough as nails, impervious to oil and you can clean it with a pressure washer.
#7 Re: Garage Floor Tiles
Post by Gfhug » Wed Jul 05, 2023 8:35 am
Thanks for the various comments. Yes, paint would be a good solution but the floor is uneven and if anything needs completely relaying, which isn’t convenient or easy to do with two cars, one on a rotisserie, and with oil stains not taking any new surface well.
That’s why tiles might be the best idea to give a nicer surface. My only experience with tiles have been some inexpensive ones that wouldn’t take the weight of a trolley jack or axle stands, but are useful as a nicer surface to walk on when working around the cars.
#8 Re: Garage Floor Tiles
Post by mgcjag » Wed Jul 05, 2023 8:45 am
Hi Geoff....an easy quick cheap surface to cover old not good concrete surfaces is 8x4 sheets of hardboard...iv had some down for 6 years now...its ready for a change..gaffer tape it at the joints....my concrete was a bit flakey so not suitable for epoxy paint....Steve
#9 Re: Garage Floor Tiles
Post by Heuer » Wed Jul 05, 2023 9:44 am
Interlocking tiles require a flat surface so any unevenness will need to be addressed. This is usually done by spreading a self levelling screed.
#10 Re: Garage Floor Tiles
Post by Gfhug » Wed Jul 05, 2023 4:19 pm
Alan, as topic author I apologise for stealing your topic but hope you’ve got your answers as well.
Some very good advice and information for which my thanks to all.
#11 Re: Garage Floor Tiles
Post by Series1 Stu » Wed Jul 05, 2023 5:25 pm
David is right, but if you're going to the trouble and expense of laying a self levelling screed then I would epoxy paint it after it has cured and before it gets contaminated with oil, etc.
However, my experience of self levelling screeds is that they don't really, without a lot of help.
ALAN COCHRANE
#12 Re: Garage Floor Tiles
Post by ALAN COCHRANE » Thu Jul 06, 2023 7:39 am
Thanks everyone for your responses. I’m fortunate in having a brand new, uncluttered floor which is level. I have decided to go for these tiles:-
They get great reviews and are very hard wearing.
Geoff no need to apologise I’ve done the exact same thing on other threads.
Alan Cochrane
#13 Re: Garage Floor Tiles
Post by Series1 Stu » Thu Jul 06, 2023 9:15 am
Interesting, and a decent price (these days). But:-
How do you cover a whole floor when they are only slotted on two sides?
They would have to be laid in double width strips with no interlocking between them.
Polse7317
#14 Re: Garage Floor Tiles
Post by Polse7317 » Thu Jul 06, 2023 12:45 pm
Hi Alan i have done what you expect : Epoxy on a flat concrete and some paths with smooth tiles , the one you have on your last post.
But BIG WARNING : the Epoxy is VERY slippery..... when wet ( ask me why...!)
Monkeyfinger
#15 Re: Garage Floor Tiles
Post by Monkeyfinger » Thu Jul 06, 2023 1:58 pm
Alan - have you checked these? They look exactly like the packs that I have previously bought from Costco, which come with removable edge finishing strips. Whilst they are great as a cushioned floor for standing or kneeling, they are not suitable for heavy loads, and will certainly squash under an axle stand etc. Just suggesting you check them before leaving Screwfix...
#16 Re: Garage Floor Tiles
Post by Heuer » Thu Jul 06, 2023 1:59 pm
Expoxy is lethal if your feet are wet, it was the reason I covered it with the tiles. Looks great but the chances are you wont when your feet slide from under you!
ALAN COCHRANE
#17 Re: Garage Floor Tiles
Post by ALAN COCHRANE » Thu Jul 06, 2023 7:23 pm
They're marketed as garage floor tiles in the blurb so should be OK. The tiles are also marketed as non slip and have the checker plate relief on them for enhanced grip.
I checked the reviews and several people were singing there praises as garage floor coverings.
Only time will tell I suppose.
Alan Cochrane
#18 Re: Garage Floor Tiles
Post by Gfhug » Thu Jul 06, 2023 7:28 pm
Alan, might it be worth just getting one set and see how they perform either with the weight of the car wheels on them or moving a trolley jack or lifting the car onto axle stands. If they work great and buy the rest, if not then you’ve only lost the cost of one set that you might use elsewhere. Just a thought. Good luck.
Fspp369
#19 Re: Garage Floor Tiles
Post by Fspp369 » Sun Jul 16, 2023 8:26 am
Alan
I tried these tiles,, of the appropriate industrial grade, on my new floor. They were quite pretty and pleasant to walk on but to work on they were less than optimal!
They moved easily when rolled over by a laden trolley jack, which became much harder to move itself. Anything that sits on them in one place for more than a few hours leaves a mark. Unless your axle stands have big feet, you will probably find the matting ends up “incised”.
If you want a surface that stands up to the usual garage environment, avoid any tiles of ant sort of foamed neoprene, if you use thinner tougher “vinyl” type interlocking tiles glue these down. Better still, I.M.O is to buy industrial machine shop flooring on the roll and stick it down.
Or even better, longer lasting and colour selective is use epoxy floor paint. Two or three layers applied at the proper intervals over a floor which has if necessary been scrabbled and repaired. If you thin the first coat by 50% and let it soak in that will stabilise the concrete..When finished you will have a floor that is able to withstand almost any point loading, solvent or oil you may care to use, and it will be easy to clean up and roll stuff around.
Good luck …get painting with a long reach roller. Be radical go for grey. :bigrin: :bigrin: :drinkingcheers:
Peter {XKE V12HE efi}
XKRS
Octavia VRS.
