Tacho stopped working
colinevans
Topic author - Posts: 180
#1 Tacho stopped working
Evening all. My S2 came back from the trimmers (dash came out) with a few electrical gremlins which were easily fixed, but the tacho has stopped working. The car has elec ignition but always has had and nothing has changed there.
Car starts and runs fine so no ignition issue that I can see, and testing shows voltage at the green and whites. After reading other old posts I suspected an earth issue so hooked up an earth to the case body but no joy.
I have just pulled the tacho apart and I can’t see anything obvious. There is continuity from the green wire to the board and around the white loop. The small earth from the board to the metal body is also showing continuity.
My only thought is that screws that hold the board etc to the case aren’t providing a good enough earth so I can clean the connections up and add a ring connector to the outside of the case and run to a good earth if that might help. Otherwise I am scratching my head and at the end of my limited electrical skills, so any suggestions would be gratefully received. Can send pics if it helps.
Cheers, Colin.
Cheers, Colin.
Colin
Series 2 OTS, 280SL
Series 2 OTS, 280SL
#2 Re: Tacho stopped working
Hi Colin, this sounds a very familiar story, my tach was not working properly after mine came back from the trimmers, although mine’s an S1 with the tach driven off a rev generator. During the trimming process i had tidied up all the gauges - light cleaning, new bezels and gaskets. I recently took the tach back out as i’d tried all other options and removed the glass and bezel and flicked the needle around a bit to give it some encouragement. On refitting it looks like that has got it working! Just thought I’d mention it in case this helps you at all.
Darryl
colinevans
#3 Re: Tacho stopped working
Thanks for the tip Darryl. Sadly I have just put it back together with a new earth on the case screws and still nothing! Frustrating but not unusual!
Colin
Series 2 OTS, 280SL
Series 2 OTS, 280SL
#4 Re: Tacho stopped working
Are you sure that the white loop wires are the right way round ?
It’s a while since I had this system but I seem to recall that the little bracket with the wire loop and plastic holder inside it can be fitted the wrong way around and if so the tachometer doesn’t work.
Five minute job to undo the knurled nut and turn it around
Tim
Tim
colinevans
#5 Re: Tacho stopped working
Hi Tim. The 3 way connector (2 whites and green) can only go one way, and the actual connections haven’t been touched, only the main block was disconnected then reconnected as far as I know. Thanks anyway though.
Colin
Series 2 OTS, 280SL
Series 2 OTS, 280SL
#6 Re: Tacho stopped working
Ahh,
You have the later block -I understand that. Do the white wires then go directly into the tach case?
colinevans
#7 Re: Tacho stopped working
Yes, exactly right Tim
Colin
Series 2 OTS, 280SL
Series 2 OTS, 280SL
colinevans
#8 Re: Tacho stopped working
As an update, borrowed another tacho this afternoon, plugged it in and it works fine, so at least I know what needs doing!
Colin
Series 2 OTS, 280SL
Series 2 OTS, 280SL
colinevans
#9 Re: Tacho stopped working
Now gone off to Speedy Cables. I assume I can put a loop across the two white cables in the remaining part of the connector block and keep driving in the meantime?
Thanks all.
Thanks all.
Colin
Series 2 OTS, 280SL
Series 2 OTS, 280SL
