Castor adjustment
Paul bow
#1 Castor adjustment
Post by Paul bow » Sun Oct 15, 2023 7:28 am
Hi guys..
I seems to me after a full rebuild that the castor needs adjusting on the steering. I say this as you find yourself steering yourself out of a corner rather than the wheel centring itself.
I understand ideal is 2 deg positive.
I have no idea how to take this measurement.. any help gratefully received.👍
S1 2+2 manual. (Sold)
#2 Re: Castor adjustment
Post by mgcjag » Sun Oct 15, 2023 7:38 am
Hi Paul....already covered quite a lot on the forum. ...see similar topics below and this one
viewtopic.php?f=3&t=19194
you need a camber/caster guage....the service manual tells you how to adjust the upper wishbone....Steve
Paul bow
#3 Re: Castor adjustment
Post by Paul bow » Sun Oct 15, 2023 1:12 pm
Thanks Steve much appreciated 👍
#4 Re: Castor adjustment
Post by chrisfell » Sun Oct 15, 2023 6:50 pm
I used a plumb line (and basic trig) hanging close to the top and bottom ball joints with the car on a level surface. It is accurate enough to set each side to within manufacturers tolerances.
Paul bow
#5 Re: Castor adjustment
Post by Paul bow » Mon Oct 16, 2023 6:03 am
Hi Chris.. could you elaborate on that a bit more for me, sounds like just the approach I’m after 👍
#6 Re: Castor adjustment
Post by mgcjag » Mon Oct 16, 2023 7:47 am
Hi Paul....have a read here..and the JL link it may help and it explains Chris useing a plumb line..Steve viewtopic.php?f=4&t=10542&hilit=Castor+adjustment note a good starting point is 1/2in thread showing at the front of the upper wishbone adjuster.....
eddiecross
#7 Re: Castor adjustment
Post by eddiecross » Mon Oct 16, 2023 4:14 pm
If you can borrow a caster/camber gauge....(I'm in Egham!)
This is how I set the castor and camber. Jacked to level across the car and at the correct ride height
Also Trackrite tracking gauge
Eddie
67 FHC
Paul bow
#8 Re: Castor adjustment
Post by Paul bow » Mon Oct 16, 2023 7:03 pm
Thanks Eddie I was looking at that gauge on machine mart.. pleased to hear that it comes recommended, and thanks for the offer.
I have very little knowledge on this as you are about to find out, infact I just picked the car up from Northampton motorsport who were going to set it all up for me, unfortunately their technical wizardry equipment did not clear the wire wheels, hence… I’ll do it myself.
Anyhow the question i can’t get my head around is why does the ride height have to be that as the same as it would be on its wheels on the floor for the adjustment on the castor?
I would have thought so long as the axle stands are under the bottom wishbone thus compressing the torsion bars and the car is level from front to back that would be ok?
Sorry, probably a really straight forward explanation and I’m making an easy job difficult! :banghead:
#9 Re: Castor adjustment
Post by mgcjag » Mon Oct 16, 2023 7:41 pm
Hi Paul.....Jaguar give settings in the manual based on what they call "mid laden height" useing setting links to reproduce this height....however in my opinion its better to set up the car as its typically driven...driver only. with a passenger or fully loaded.....so load up you car to suit then do all your settings.....or just use the setting links..your choice..sitting on its wheels on slip plates is the easy way... Steve
Paul bow
#10 Re: Castor adjustment
Post by Paul bow » Mon Oct 16, 2023 8:38 pm
You know what Steve.. I’ve restored this any many others from complete wrecks, but this castor alignment is doing my head in !! 😂
Setting links? Sorry but I’m a miss as to what these are..
And the tool that our friend above has shown in the pic is mounted on the disc, wheels removed..
I’ve got the technical data just struggling to know the method, having read other posts on it I’m still none the wiser.
I’ve got it how to adjust the castor but it’s the measuring of it that’s defeating me.
In desperation I called JD classics being just up the road thought I’d just put it in there after the disappointment at Northampton..
The guy there informed me no problem but it’ll be 2 days work, at least, I didn’t have the courage to ask what the hourly rate was !! 🤣
#11 Re: Castor adjustment
Post by Series1 Stu » Mon Oct 16, 2023 9:15 pm
Hi Paul.
The setting links are to ensure that the car sits on the floor, which must be level, with the factory ride height settings. This is important because it affects the castor angle. This can be explained if you imagine raising the rear wheels off the ground while the front wheels are still on the floor. You can see that the upper wishbone will rotate forward around the axis of the stub axle thus changing the inclination of the stub axle carrier and, therefore, the castor angle.
#12 Re: Castor adjustment
Post by abowie » Mon Oct 16, 2023 9:31 pm
Bollocks. It should take perhaps 15 minutes.
viewtopic.php?f=3&t=14168&p=116037&hili ... en#p115191
#13 Re: Castor adjustment
Post by DWW » Tue Oct 17, 2023 1:59 am
They gave you 'a not interested in the job' quote
#14 Re: Castor adjustment
Post by abowie » Tue Oct 17, 2023 3:19 am
More than likely it was so they could drive the car to the wheel alignment shop one day and pick it up the next.
Paul bow
#15 Re: Castor adjustment
Post by Paul bow » Tue Oct 17, 2023 4:15 am
abowie ..’drive it to the shop and pick it up the next!’
That made me laugh ..😂😂
flatfloor 3.8
#16 Re: Castor adjustment
Post by flatfloor 3.8 » Tue Oct 17, 2023 6:48 am
Hi, i have all the equipment needed to do this job ( turntables, camber castor gauge, setting links Etc ) you are welcome to borrow them. I live in Thorpe Bay, Essex.
Bill S1 3.8 OTS.
#17 Re: Castor adjustment
Post by chrisfell » Tue Oct 17, 2023 4:31 pm
Paul,
The link to Jag-Lovers hasn't got this photo.
Sort of helps to see exactly how i did it.
Paul bow
#18 Re: Castor adjustment
Post by Paul bow » Wed Oct 18, 2023 4:05 pm
Many thanks guys great help as ever..
And Chris that picture explains exactly how you did the job, much appreciated.
Apparently moss (Angus) are in the process of an all singing and dancing set up, and should be up and running in a few weeks, I might hold off till then, thanks all 👍
