6 cyl engine stand
#1 6 cyl engine stand
Hi, has anyone got an 6 cyl engine stand I can borrow or with charity donation. Looking for the type the secures on a side not the bell housing end. Thanks in anticipation ..Pat
alfazagato
#2 Re: 6 cyl engine stand
I have a two sided "frame" engine stand which allow the engine to be turned through 360 degrees which is for sale. Easily strong enough for a Jaguar engine and adjustable in width for bigger units. Send me a PM if interested....I am in South West London.
Series 1.5 FHC
#4 Re: 6 cyl engine stand
If you were thinking of this type
viewtopic.php?f=3&t=11938&p=139269&hili ... nd#p139269
then the prototype that SNGB used to base their production from is somewhere floating around the UK, and I can probably arrange for you to borrow it.
How long do you need it for ?
#5 Re: 6 cyl engine stand
Many thanks, probably a month or so. Where abouts are you, or it and I will collect. Thanks
#7 Re: 6 cyl engine stand
See my PM.
#8 Re: 6 cyl engine stand
Rory, should it become available in 2024 when I hope to tackle my OTS engine I’d be pleased to borrow it for a suitable donation or even buy it to then loan out to others on the forum.
#10 Re: 6 cyl engine stand
Rory. If you pm you telephone number I will call you.
Tia
Tia
#12 Re: 6 cyl engine stand
Message sent just now.
#14 Re: 6 cyl engine stand
Made an engine cradle adapter. It’s not a new idea but changed slightly in that I’ve used 4 small plates to bolt the engine cradle bracket as I didn’t have any 60 mm thick walled pipe.
#15 Re: 6 cyl engine stand
That's a very good bit of lateral thinking, Pat.
I wish it had been my idea, it's a much better approach to the problem.
#16 Re: 6 cyl engine stand
I’m but standing on the shoulders of giants. Credit must go to the originator.
