Hose from inlet manifold to bulkhead
rfs1957
#21 Re: Hose from inlet manifold to bulkhead
Post by rfs1957 » Thu Mar 14, 2024 12:16 pm
Might be delicate electrolytic pairing, the brass and the aluminium, although the manifold temperature sensor and the thermostat seem to survive ......... and as the steel original tends to weld itself to the aluminium anyway, the brass might be no worse a choice :scratchheadyellow:
tim wood
#22 Re: Hose from inlet manifold to bulkhead
Post by tim wood » Thu Mar 14, 2024 6:36 pm
And here it is fitted
You have to sacrifice a 7/8 spanner by heavily grinding the edges due to the design of the manifold
#23 Re: Hose from inlet manifold to bulkhead
Post by bitsobrits » Fri Mar 15, 2024 9:48 pm
Or just use a deep well 12 pt socket...
tim wood
#24 Re: Hose from inlet manifold to bulkhead
Post by tim wood » Sat Mar 16, 2024 4:24 pm
As a footnote to this
I’ve now fitted the right angle hose that runs between the manifold and the water pump.
Sourced from one of our favourite suppliers it needed trimming by around 12mm on each end to get a reasonable fit. In reality it should be a straightforward job ( nothing is!) but my guess is that the supplier just sources a generic near enough hose leaving us to make it work.
If Fosseway can do it as a small provider then why can’t the big boys get it right .
( sorry for another rant )
#25 Re: Hose from inlet manifold to bulkhead
Post by mgcjag » Sat Mar 16, 2024 4:35 pm
If it was easy then everyone would be doing it and E types would be cheap :drinkingcheers:
