PierreW
Post
by PierreW » Fri Jul 12, 2024 1:22 pm
How to replace the rear core plug of the engine ? Mine has been ejected two days ago
big scare and cloud of steam....
is this possible without the great engine/gearbox "extraction" ?
Pierre
Jaguar MK2 1967 since 1980
Lotus Seven 1963 since 2015
XKE S1 1964 OTS since 2023
Post
by DWW » Fri Jul 12, 2024 1:57 pm
I had one of those eject a while ago, it was the last one on the exhaust manifold side closest to the firewall, like you much steam and big scare, luckily I was close to home and after some cool off time managed to limp home. I managed to instal a new one in situ although it was not that straight forward as there is limited room and had to use a socket extension to apply between the core plug and hammer. I doubt it can be done in situ unless someone know better.
PierreW
Post
by PierreW » Fri Jul 12, 2024 3:54 pm
mine is the plug situated at the rear end of the engine parallel to the firewall ...so at the worst place
with very little access....
- Moderator
Post
by mgcjag » Fri Jul 12, 2024 4:26 pm
Hi....best option .ay be to llook at the expanding type of core plug with a center bolt to expand it..Steve
Post
by DWW » Fri Jul 12, 2024 5:24 pm
Bloody good idea, first time I hear of it.....but will the rubber in it last?
PierreW
Post
by PierreW » Sat Jul 13, 2024 5:28 am
Very, very, very interesting , thank you Steve :-)
wagstefan
Post
by wagstefan » Thu Jul 18, 2024 11:09 pm
Dorman 568-011 - had to do the same. Take care when ordering over ebay.. Some selling one for the price of five.
Angus saved my life in that regard and gave me that hint.
But don't complain about spending 2 hours of trying to get bolts back in place for the rear engine/gearbox support bracket. I almost lost my mind....
Good luck!
wagstefan on Fri Jul 19, 2024 9:26 am, edited 1 time in total.
PierreW
Post
by PierreW » Fri Jul 19, 2024 6:22 am
@ wagstefan
I ordered 5 in the US 3 days ago Thanks
david muir
Post
by david muir » Fri Jul 19, 2024 11:03 am
Are these Copper plugs available in UK?
1964 3.8 FHC
PierreW
Post
by PierreW » Fri Jul 19, 2024 1:46 pm
I ordered mine on amazon Us because I didn't find them nowhere else...
rfs1957
Post
by rfs1957 » Tue Jul 23, 2024 12:17 pm
Hey Pierre,
If you get 5 and don’t need them all, would you sell me one perhaps ?
Sounds like a good thing to have in the tool-kit.
Thanks.
david muir
Post
by david muir » Wed Jul 24, 2024 12:27 pm
is the plug on the rear of the block 1" in diameter ( as opposed to 1 5/8 " at sides)?
1964 3.8 FHC
Allrand
Post
by Allrand » Wed Jul 24, 2024 2:38 pm
No it's the same size. There's a smaller one on the inlet side near to the rear corner & higher than the others.
Randall Botha
