OK, so this a thread about noisy stainless steel exhausts.
As an aside, appended is some information about improving the torque band by biasing it down to where road cars can most profitably use it.
https://aj6engineering.co.uk/tt-systems-explained/
Noticeable is that the v12 is just twin six cylinder engines fired 60' apart. What XK engined owners with standard manifolds can do is measure the length of the tubing down to where the TT tubes join about 3-4ft away and replace the middle silencers with a joining pipe there. If the tubing is the same diameter as the TT system, it ought to be a neat and cheap way to get better overtaking performance on the road.
By the same token, fitting "fast road cams" that "assist" at higher rpm is counterproductive. What you actually want on the road is a camshaft that delivers maximum torque down at 1700-3500rpm, because that's the rpm you are probably doing when you overtake or accelerate. That'll be a camshaft with a
lower duration, not higher. Paradoxically, that'll deliver a lower overall horsepower than standard, but it'll appear to be faster than the traditional "performance" option.
