As stated by a senior Rolls Royce engineer to a disgruntled American owner when he complained about oil weeping from the engine.
New Developments In Rear Crank Sealing
#21 Re: New Developments In Rear Crank Sealing
Steve, “acceptable weepage”?
#22 Re: New Developments In Rear Crank Sealing
Hi Geoff...yes but that's what a correctly fitted rope seal does...and it dosnt cost £300 for the seal and around £300 odd to have the crank groung to fit....Steve
#23 Re: New Developments In Rear Crank Sealing
Ok Steve, so long as you promise to visit and correctly fit the rope seal for me
The alternate is that Rory will do all the work of fitting this new wonderful seal for me
#24 Re: New Developments In Rear Crank Sealing
Typically a leak at the rear is the rear sump seal...which does need care when fitting...Steve
#25 Re: New Developments In Rear Crank Sealing
1965 S1 4.2 FHC (early)
#26 Re: New Developments In Rear Crank Sealing
Hi all,
just wanted to know if anyone has fitted the flexi-seal" from Rob Beere and is happy with it?
Frank
Frank
Frank
1969 S2 FHC
1964 AH 3000 MK3
1969 S2 FHC
1964 AH 3000 MK3
#27 Re: New Developments In Rear Crank Sealing
Hello Pat, any comments on the new seal, yet?
#28 Re: New Developments In Rear Crank Sealing
Chris in post 19 above said Fitted one in March 2023. 3000 miles since fitting and just get the occassional drop on the garage floor.
