Do XJS rear brake calipers fit series 3
Yeldaw
#1 Do XJS rear brake calipers fit series 3
Post by Yeldaw » Thu Jun 12, 2025 7:18 am
According to the etype parts list the rear calipers on the series 3 have part numbers 11832/3 but some sites suggest you can use the xjs calipers part numbers AAU3378/9. Can anyone confirm this and whether they are a straight fit without any modifications. Also what are the differences between the two as they look identical in the pictures. The price for the XJS version are considerably less than those given for the etype.
1972 S3 2+2 with HE V12
#2 Re: Do XJS rear brake calipers fit series 3
Post by mgcjag » Thu Jun 12, 2025 9:00 am
Hi Dave...I have no idea if there are minor differences....the AAU number you quote was also used in Xj6 models....they will fit on the diff...note the handbrake caliper is different on the E type.....re price are you comparing like for like....originals refurbished vs aftermarket repro?...stainless pistons etc....originals refurbished are best....if you use repro you could always run into issues
Yeldaw
#3 Re: Do XJS rear brake calipers fit series 3
Post by Yeldaw » Fri Jun 13, 2025 12:00 pm
Thanks, I was looking at the new ones, I think I will go with the etype part numbers to be on the safe side.
