On dismantling my starter motor for a deep inspection and cleaning, I found that the internal gears were lubricated with a sort of (old) oil.
Shouldn't I use a (new) grease instead?
Starter motor gear lubrication
Philippe-J.
Topic author - Posts: 272
#1 Starter motor gear lubrication
- Attachments
- IMG_5021_red.JPG (64.25 KiB) Viewed 1701 times
Philippe-J.
#3 Re: Starter motor gear lubrication
Excellent Bob, thank you!
I found the info about Shell SB2628 that I needed. It's a "polybutyle Cuprisil (PBC) corrosion resistant grease". Sounds better than the oil I found. However a quick search on the Internet shows it is not easy to find.
BTW this document contains a simpler explanation than the workshop manual about the way the starter motor works.
