Separating front hub from disc
Knightrider
#1 Separating front hub from disc
Post by Knightrider » Sun Oct 12, 2025 4:28 pm
I started what I thought would be a simple job this afternoon - removing the front discs to either clean them up or replace them. I have removed the hub assembly fine - caliper off, pin out, castle nut off. I have also removed the 5 bolts securing the disc to the hub.
But...the disc is stuck fast to the hub. No matter how much persuasion I use, I cannot separate them. Any tips? I don't have access to a press....
1966 Series 1 2+2
#2 Re: Separating front hub from disc
Post by mgcjag » Sun Oct 12, 2025 7:16 pm
The disc should just be bolted to the hub...no press fit etc...probably just corrosion holding it together...but who knows what a previous owner has done.....welded it etc..hold the hub and give the disc a few serious whacks with a big mallet should seperate it...or a chisel where disc mates to hub....Steve
#3 Re: Separating front hub from disc
Post by bitsobrits » Mon Oct 13, 2025 1:25 am
Some heat from a propane torch or similar applied to the mounting flange area would be helpful.
Knightrider
#4 Re: Separating front hub from disc
Post by Knightrider » Mon Oct 13, 2025 8:16 am
I've already tried the hitting it hard approach - have added some PBX and left it overnight. Will try again and apply some heat...
1966 Series 1 2+2
