Freddie Wrote:
It works! Now to slide the TB off….
But of course!
And as you have probably discovered, you don't have to disengage the wishbone from the Torsion Bar, if your only endeavor is to replace the bushes. However, when replacing bushes, I like, at the least, to clean the wishbone thoroughly, but usually to do a full refurbishment of the wishbone components.
