Stuck distributor
Knightrider
#1 Stuck distributor
Post by Knightrider » Sat Jan 10, 2026 5:59 pm
Set about replacing my original distributor with a 123-ignition one today, and hit a snag - I cannot get the old one off no matter what I try! I have loosened the clamp, and to be sure undone the bolt that holds the clamp to the engine - the clamp rotates around the base of the distributor so I know it isn't that.
It is stuck fast - won't rotate, won't pull. I have tried hitting, prying, twisting and pulling and have achieved nothing other than cracking the vacuum when the pry bar slipped....
Any tips? Am I missing something?
1966 Series 1 2+2
#2 Re: Stuck distributor
Post by mgcjag » Sat Jan 10, 2026 7:26 pm
Sounds like it's seized in the block....get plenty of penetrating oil in there.....you previously said your fitting a 123 ....so needs must and do whats needed to twist the dizzy out....but....plenty of oil for a good few days first...Steve
Knightrider
#3 Re: Stuck distributor
Post by Knightrider » Sat Jan 10, 2026 7:27 pm
Thanks. Have soaked in in plusgas and will keep going...
1966 Series 1 2+2
#4 Re: Stuck distributor
Post by mgcjag » Sat Jan 10, 2026 7:41 pm
Not uncommon for coolant to leak from the thermostat houseing and over the dizzy
Robbiee
#5 Re: Stuck distributor
Post by Robbiee » Sun Jan 11, 2026 5:13 pm
Have you tried with a hot engine block?
Might be enough to shift it?
Knightrider
#6 Re: Stuck distributor
Post by Knightrider » Sun Jan 11, 2026 5:33 pm
I've tried heat. Not sure if it will run now as I've cracked/damaged the vacuum advance. Will keep going with the penetrating oil for a few days and see if it frees...
1966 Series 1 2+2
#7 Re: Stuck distributor
Post by mgcjag » Sun Jan 11, 2026 6:11 pm
You could try a torch/blow lamp/heat gun to heat the houseing area below the dizzy
#8 Re: Stuck distributor
Post by Gfhug » Sun Jan 11, 2026 6:17 pm
With a fire extinguisher to hand, please!
Knightrider
#9 Re: Stuck distributor
Post by Knightrider » Thu Jan 22, 2026 5:13 pm
As there are lots of unresolved threads on this topic I thought I'd update. It took 1.5 weeks, but its out!
I followed the advice and heat cycled with a heat gun (not a torch) and doused in plusgas daily for a week. After a week, I could get a small amount of rotational movement with a large pry bar. I then continued with heat, small rotational movements, and plusgas for a few more days, then eventually got it out when it was moving more freely - a bit pair of channel locks on the top to rotate back and forwards, with a big pry bar applying upward pressure under the flange.
The old dizzy is toast, but I have a 123 to install so I'm not too upset!
1966 Series 1 2+2
#10 Re: Stuck distributor
Post by mgcjag » Thu Jan 22, 2026 5:37 pm
Great....if it was easy it wouldn't be enjoyable :bigrin: thanks for the update...Steve
#11 Re: Stuck distributor
Post by DWW » Thu Jan 22, 2026 5:47 pm
:yeahthat: hope you took good care of the block.....
#12 Re: Stuck distributor
Post by Gfhug » Thu Jan 22, 2026 6:08 pm
I dare you to send it to the Distributor Doctor for overhaul
Would love to see the look on his face :bigrin:
Knightrider
#13 Re: Stuck distributor
Post by Knightrider » Thu Jan 22, 2026 6:34 pm
DWW wrote: ↑
Yes - I was careful to use the old clamp to protect the block... All looks fine.
1966 Series 1 2+2
Knightrider
#14 Re: Stuck distributor
Post by Knightrider » Sat Jan 24, 2026 7:54 pm
123 installed today and running well. Thanks for all the tips!
Vacuum pipe is a bit too short to reach the 123 - any alternatives to reach it...?
1966 Series 1 2+2
#15 Re: Stuck distributor
Post by mgcjag » Sat Jan 24, 2026 8:10 pm
Just extend it with a piece of rubber thin hose
Knightrider
#16 Re: Stuck distributor
Post by Knightrider » Sat Jan 24, 2026 9:09 pm
Will see what I have laying around.
1966 Series 1 2+2
