Speedo repair and calibration
#1 Speedo repair and calibration
Since Speedograph Richfield have ceased trading who is everyone using ? My “refurbished” Speedo has stopped working and I need it looked at hopefully with a quick turn around. I also want it calibrating to suit my 3.07 differential. There are usually one or two artisans around who do this sort of work. All help much appreciated. Thanks. Andrew
#2 Re: Speedo repair and calibration
Speedy cables seems to be the other option from posts on the forum. Sad to hear of another old company finishing business with no-one interested in taking it on.
Trevor Part
#3 Re: Speedo repair and calibration
Try Flannery Speedometer Repairs. Tel 01594 861095. Had my speedometer repaired this year.
Very helpful and good work completed.
#4 Re: Speedo repair and calibration
Thank you Guys, another name was mentioned in the JEC technical help section, that of JDO Instruments. Has anyone used them and able to recommend please? thanks andrew
#5 Re: Speedo repair and calibration
A search for JDO gave 30+ responses. You can see thoughts of them there.
#6 Re: Speedo repair and calibration
thank you. and about 30 plus differing opinions sadly!
#7 Re: Speedo repair and calibration
If you speak to Andy Rayner from Hutsons Motor company (01274669052) he will recommend a company that he uses, I had my speedo recalibrated this year by them but I can't remember the contact details,
Ian
Ian
1965 series 1 ots
1972 triumph spitfire
2016 Caddy van
2016 Caddy van
#8 Re: Speedo repair and calibration
Ian
Ian
1965 series 1 ots
2016 Caddy van
2016 Caddy van
#9 Re: Speedo repair and calibration
thank you. I know Andy , I will give him a call on monday. Thanks for the advice. .
#10 Re: Speedo repair and calibration
Caerbont in Wales do this kind of work, and they also manufacture all the Smiths-branded instruments as far as I am aware.
Their work has always seemed okay to me, when they have overhauled or re-calibrated speedos and rev-counters on my cars.
They did a really-convincing new dial on the Mini, with extra and re-labelled warning lights, and higher numbers in the illegal-speed range that didn’t figure on the original.
The downside is that you feel like you are dealing with gormless civil-servants with zero interest in the product, imagine Andy Rayner only in negative.
#11 Re: Speedo repair and calibration
Yes I have dealt with them before. Thank you
