Morning all, possibly not one for technical but maybe?
I will be flushing the then refilling and the cooling system on the car at the weekend after fitting a new header tank and otter switch.
I have managed to get some Bluecol and I remember’back in the day’ we always added a bars leaks to the system as well.
Does anyone else do this still or do you use just blue ol and water?
I have very soft water at home as well as we have a softener fitted. I am thinking softer water is also better for the system as well??
Thanks all, Steve.
Bars leaks
Stevemorris
Topic author - Posts: 174
#1 Bars leaks
Steve, UK.
1965 Jaguar ‘E’ Type FHC
#2 Re: Bars leaks
Hi Steve...yes bars leaks was used from the factory....personally I fill with plain water...run it a few times and check and give any leaks....if u can't fix them then add your choice of sealant....when I have no leaks I drain down and refill with coolant.....distilled water and bluecol....Steve
#3 Re: Bars leaks
A water softener adds salt to your water. I guess it’s an option though
Trevor.
#4 Re: Bars leaks
A chemist friend recommends reverse osmosis (RO) purified water for engines with aluminum (aluminium
) and specifically against 'softened' water, due to the ionization brought on by the salt in a typical softener system.
In the U.S. at least, RO water is easy to find in gallon jugs at most grocery outlets and many convenience stores.
I generally use RO water, but will just use tap water (from my outdoor non-softened hose taps) in a pinch.
