Stromberg Carburettor mixture check
Marcusu
#1 Stromberg Carburettor mixture check
Post by Marcusu » Mon Sep 21, 2026 8:26 am
Hi all,
Quick question: is it possible to check if Stromberg carbs are running rich by lifting the piston and seeing if the engine speeds up continuously like you can with SU carburettors?
Cheers,
Marcus
S3 FHC BRG
#2 Re: Stromberg Carburettor mixture check
Post by Heuer » Mon Sep 21, 2026 10:42 am
These downloadable guides from the Forum Knowledge Base tell you everything about Stromberg:
Stromberg Overhaul Guide (74 pages!): https://www.dropbox.com/s/clmwrlgonv8gx ... 2.pdf?dl=1
Stromberg manual (Leyland): https://www.dropbox.com/s/kd8urr3l411dh ... d.pdf?dl=1
Stromberg Needle guide: https://www.dropbox.com/s/domenkpzexkqw ... e.xls?dl=1
Stromberg Strip down by David Lacey: https://www.dropbox.com/s/48pmsd9osrrwi ... n.pdf?dl=1
Pictorial Stromberg strip down guide: http://www.howacarworks.com/fuel-system ... arburettor
Marcusu
#3 Re: Stromberg Carburettor mixture check
Post by Marcusu » Mon Sep 21, 2026 12:41 pm
Thanks David, I will take a look.
Cheers, Marcus
S3 FHC BRG
