A Cat in the Nordics
boss_time
Sweden
#1 A Cat in the Nordics
Post by boss_time » Sat Oct 10, 2026 7:33 pm
Hello everyone,
I’ve been lurking around the forum over the summer, soaking up as much collective wisdom as possible. Now I felt it was high time to step out of the shadows and introduce myself properly.
I am currently in the process of taking over custodianship of my grandfather’s E-Type. Due to advancing age and reduced mobility, the car has spent increasingly more time sitting idle over the past decade. For my part, the summer has largely been about getting to know the car and mapping out the backlog of servicing and repair work ahead.
Here are a few photos of the car. As a small bonus, I’ve also attached a picture of the very first step in my maintenance plan: a set of custom jacking blocks for the picture frame and IRS.
(Unfortunately, I made the mistake of making them a bit too nice—to the point where I couldn’t bear the thought of scratching them. In the end, I had to knock together a plain, unpainted sacrificial set just to actually lift the car...)
Looking forward to learning from you all and sharing the journey!
Best regards,
Erik
Erik
S2 FHC 1969
#2 Re: A Cat in the Nordics
Post by Gfhug » Sun Oct 11, 2026 12:33 pm
Erik, welcome to the best place for all things E Type. So much advice and help plus all the technical knowledge to refer to that you should soon get a response to questions or find the answers through searching.
Good luck with getting the car back to tip top condition. Note that if you buy parts from SNG Barratt then membership of clubs like the JEC or JDC can get you a discount.
boss_time
Sweden
#3 Re: A Cat in the Nordics
Post by boss_time » Tue Oct 13, 2026 6:47 pm
Thank you, Geoff!
I've mostly tinkered with turbocharged SAABs previously, primarily the models from the late '80s up until the bitter end in 2010. So I'm really looking forward to the challenge of getting familiar with carburettors, points, and all the mechanical nuances of a true classic.
That's a great tip regarding the club discount—though just my typical luck, I already placed a rather hefty order with SNGB this summer for all sorts of bits and bobs! :lol:
I’ve just commenced step one: changing fluids in the engine (Millers 20W-50), gearbox (Red Line MT-90), and the rear diff (Red Line 75W-90 LS).
Somewhat surprisingly, the copper washers I bought didn't fit the engine sump plug. I assumed it shared the same dimensions as the gearbox drain plug, but my car seems to differ from the workshop manual.
Could it be that a previous mechanic stripped the original sump threads and tapped it for an oversized plug? The head takes a 1" socket and the outer thread diameter measures almost exactly 3/4". (Oh boy, fractional imperial measurements are certainly a learning curve for a metric brain...)
I've attached a couple of photos of the plugs and washers—any thoughts or wisdom on this would be much appreciated!
Erik
S2 FHC 1969
JerryL770
#4 Re: A Cat in the Nordics
Post by JerryL770 » Thu Oct 15, 2026 5:09 pm
boss_time wrote: ↑
Welcome to the forum Erik. Yes, I think the standard size for the sump drain plug is 5/8" and it could be they originally used UNF which is why it is easily stripped. I'd expect it to be 5/8" UNC
Best of luck with your work on the car though it does not look like there's an awful lot of re-commissioning to do. :smile:
Jerry
Jerome Lunt
