Removing IRS under Quickjack?
Knightrider
#1 Removing IRS under Quickjack?
Post by Knightrider » Sun Oct 11, 2026 1:27 pm
I was chasing the reason that my handbrake keeps losing grip this weekend, and realised whilst under the car that one of my rear brake disks was heavily scored on one side. Quick investigation revealed that the previous owner (who had rebuilt the IRS as part on an ongoing restoration) had fitted one of the brake pads the wrong way round! I thought having bought the car with a refreshed IRS I could avoid having to drop it for a while, turns out I now need to replace the disk...
A couple of questions:
1. Has anyone tried dropping the IRS with the car on Quickjacks or similar? I have standard Quickjacks, lift the car about 24 inches. Am I right that if I take the IRS out sideways, it should have enough clearance? I was thinking of getting an ATV jack to drop it onto.
2. Do the Zeus replacement rear calipers use standard E-type discs and pads, or something different?
1966 Series 1 2+2
#2 Re: Removing IRS under Quickjack?
Post by Gfhug » Sun Oct 11, 2026 1:42 pm
Simon, one observation is that the IRS can topple easily if not nicely balanced on whatever you’ll put it on.
#3 Re: Removing IRS under Quickjack?
Post by mgcjag » Sun Oct 11, 2026 2:36 pm
Simon.....yes you can remove the IRS from the side....Steve
Knightrider
#4 Re: Removing IRS under Quickjack?
Post by Knightrider » Sun Oct 11, 2026 4:41 pm
Thanks. Yes - I have read that it is front heavy, so will either move the jack further forwards, strap it, or both.
1966 Series 1 2+2
Simonpfhc
#5 Re: Removing IRS under Quickjack?
Post by Simonpfhc » Mon Oct 12, 2026 6:16 am
…..and yes, the Zeus rear calipers use standard discs and pads.
62 3.8 FHC
91 Porsche 928GT
Knightrider
#6 Re: Removing IRS under Quickjack?
Post by Knightrider » Mon Oct 12, 2026 7:28 am
Simonpfhc wrote: ↑
Thanks!
1966 Series 1 2+2
Knightrider
#7 Re: Removing IRS under Quickjack?
Post by Knightrider » Mon Oct 12, 2026 8:35 pm
Just a thought - I usually place the blocks for my quickjack on the point where the trailing arm meets the body. As the trailing arms come off with the IRS, where can I safely place the rear jack blocks to safely support the car?
1966 Series 1 2+2
#8 Re: Removing IRS under Quickjack?
Post by mgcjag » Mon Oct 12, 2026 9:20 pm
Remove the trailing arms from the body first....then use your quick jacks.....Steve
Knightrider
#9 Re: Removing IRS under Quickjack?
Post by Knightrider » Mon Oct 12, 2026 9:31 pm
Thanks. So it is safe to remove the trailing arms with the car on the wheels, then jack it up on the points where they mount to the body? Should make it fairly straightforward.
1966 Series 1 2+2
#10 Re: Removing IRS under Quickjack?
Post by mgcjag » Tue Oct 13, 2026 7:18 am
Hi Simon.....If your working on the car yourself then you should ensure that whatever you do is safe.....its easier to remove the large end from the car with the suspension compressed(wheels on the ground)....otherwise its pulling at an angle....jacking on the cups could be a bit unstable do you need to be sure you have it safe.....you have a 2+2 so also have rear jackbpoints......Steve PS is the balance point stable on a quick jack with IRS removed......you dont want engine weight tipping it
Knightrider
#11 Re: Removing IRS under Quickjack?
Post by Knightrider » Tue Oct 13, 2026 12:43 pm
Steve,
Thanks for the reply. I also have a Lotus Elise so am very familiar with the risk of a car falling off a lift - if you take the wheels off, they become very unstable! I would place additional jack stands under the front of the car to keep it safe.
Presumably the issue with the trailing arm mounts is the same with a 2-post lift? Where is the "official" rear jacking point located on the 2+2?
1966 Series 1 2+2
#12 Re: Removing IRS under Quickjack?
Post by mgcjag » Tue Oct 13, 2026 12:56 pm
On a 2+2 you should have a small raised button front/rear of the cill to position your jack onto when changing a wheel......you can also support the car on the chassis rails that run either side of the exhaust...Steve ps a 2 post lift isn't a tool I would use on an E type....
