clip on mirrors
stevex75
#1 clip on mirrors
Post by stevex75 » Sun Aug 05, 2012 7:35 am
Ive got hold of a couple of clip on mirrors, one rectangular and one round. I want to use the round one as I think it will suit the car more. However i just can not see how they fix to the window frame and still allow the glass to slide up and down. Am I missing the blindingly obvious or what?
peters3103
Post by peters3103 » Sun Aug 05, 2012 8:03 am
I ended up using my clip on mirror clamped to the top edge of the door as I found it too close to see out of clamped to the window frame. If clamping to the window frame, the metal section that sits between the window channel and the frame is thin enough not to interfere.
Peter
61 E-Type FHC Opalescent Golden Sand - now sold 😕
vee12eman
Kiribati
Post by vee12eman » Sun Aug 05, 2012 8:06 am
Hi Steve,
If the mirrors are of the normal design, they may look as if they prevent the window rising, but as long as the clamp goes under the rubber channel you will find all is OK - best thing is to give it a go and see how it works out.
Series III FHC
Post by Heuer » Sun Aug 05, 2012 11:58 am
They do indeed allow the window to work but if you want to keep them attached you need to cut about 1/4" off the clamp to allow the base to sit further over the chrome. More info: http://myetype.co.uk/forum/viewtopic.php?t=1157&start=0
vee12eman
Kiribati
Post by vee12eman » Sun Aug 05, 2012 12:06 pm
Yeah, I forgot about trimming down the captive plate. However, I am very happy with my pair
Series III FHC
stevex75
#6 clip on mirrors
Post by stevex75 » Sun Aug 05, 2012 5:08 pm
Any chance of a close up to see exactly how they fit?
vee12eman
Kiribati
Post by vee12eman » Mon Aug 06, 2012 8:27 am
Try this:
and:
Series III FHC
stevex75
#8 clip on mirrors
Post by stevex75 » Thu Aug 09, 2012 3:00 pm
brilliant.thanks very much
RobMason
Post by RobMason » Sat Sep 22, 2012 5:10 am
Where can these oval mirrors be obtained?
vee12eman
Kiribati
#10
Post by vee12eman » Sat Sep 22, 2012 7:30 am
Tex Mirrors - A UK company, but they ship all over the world,
I'll look up the code, but they are the same shape as the original Series 3 mirrors, just different stalks,
Series III FHC
vee12eman
Kiribati
#11
Post by vee12eman » Sat Sep 22, 2012 7:34 am
Hi again Rob,
Mirror code is: MQO4,
Web address is:
http://www.texautomotive.com/classic_ex ... rrors.html
I phoned an order through, pretty quick and very helpful. I bought the oval mirrors here in Aus, 'cos they were out of stock at the factory and I was in a rush, but all should be good now. I bought other items, which tested the delivery and costs. Cheaper to buy from factory than aftermarket, but I needed them for a Roadworthy inspection and in a hurry.
Series III FHC
