Torsion Bars
E-TypeIP
#1 Torsion Bars
Post by E-TypeIP » Mon Oct 08, 2012 6:57 pm
Hi, can anybody please give me some advice?!? I came to move my car when I noticed it was almost touching the ground. Immediately I realised torsion bar had snapped clean in half : / I've been quoted ?324+vat is this reasonable? Also are they easy to change etc?
Cheers Ian
Ian Pickering
1996 XJS Celebration convertible - Carnival red
1971 E-type V12 2+2 FHC - Dorchester Grey
Post by abowie » Tue Oct 09, 2012 1:55 am
Checked a couple of the "usuals" GBP470 including VAT.
I've just reinstalled the torsion bars on my FHC. Not complex but you do have to remove the front hub assembly and shock. The process for getting the bars in correctly is well described in the manual.
Essentially you use a link of specified length in place of the shock to position the lower wishbone correctly when the bar has no torque on it.
I had my car on a hoist which probably made things a little easier.
e-bygum
Post by e-bygum » Tue Oct 09, 2012 5:03 pm
Ian
Make sure that any info. you get is for the S3. People wrongly assume that all three series are the same, they are not.
Do you have the ROM? Is your chassis no. pre or post 1s50064?(there are two different methods). If post do you have access to special tool JD43? Note that the setting links are different lengths for pre & post the above chassis no.
If you can't get hold of JD43 there is a work-round.
'71 S3 2+2
SESH
Post by SESH » Tue Oct 09, 2012 6:01 pm
Second hand S3 torsion bars currently on Ebay with a buy it now of ?75
http://www.ebay.co.uk/itm/Jaguar-E-Type ... 27cb81be2d
Good luck
Mike
1963 Triumph TR4 Signal Red
